Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Feb 2, 2017 at 1:12 PM
    #101
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Who is installing the bushing for you
  2. Feb 2, 2017 at 1:47 PM
    #102
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Dale's Alignment in Langley, BC. The most knowledgeable, experienced folks around. Same guys that did the bushing for @BCJake.
    With the new leaf springs, I'm getting a stupidly noticeable vibration around 25-35kph. I suspect there are two sets of different problems with my vibrations: 1) the front diff's bushing and 2) the angle of the driveshaft due to the new leaf springs.
    Item #1 will be addressed by the ECGS bushing and alignment.
    For item #2, the same shop is also installing a carrier drop, which should help, but will likely not eliminate the vibrations altogether (will know on the drive home tonight). It sounds like I'll need to get pinion shims to completely solve #2. The problem is that doing this will require essentially re-doing the entire leaf spring install, so the 3 hours of labour I paid to have it installed will go out the window. Frustrating.
    smitty99[QUOTED] likes this.
  3. Feb 2, 2017 at 1:49 PM
    #103
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    Does this replacement apply to 2wd tacomas?
  4. Feb 2, 2017 at 2:15 PM
    #104
    smitty99
    Scottsdale
    If and when I lift I'm keeping it 2" or below.
  5. Feb 2, 2017 at 2:17 PM
    #105
    0210
    Vancouver, BC
    My original lift was 1 7/8" all around. I was happy with that, except for the rear squatting down any time I put so much as a box of tissues in the bed. On camping trips I was bro-leaning like you wouldn't believe. Thus the new rear leafs. I thought I had enough weight to keep the rear lift at around 3" or a bit less, but looks like that's not the case. In hindsight, should have gone with the regular All Pro pack instead of the Expedition one. Maybe I can pull a few leaves...
  6. Feb 2, 2017 at 2:19 PM
    #106
    smitty99
    Scottsdale
    Il
    I'd probably stay with 6112s and 5160s with 3leaf progressive AAL and remove factory overload
  7. Feb 2, 2017 at 2:20 PM
    #107
    0210
    Vancouver, BC
    ICON's progressive AAL and no factory overload was exactly my setup. Long bed, canopy, roughly 150lbs of misc gear, it gave me 1 7/8" lift from stock sport suspension.
    sorgon82 and smitty99[QUOTED] like this.
  8. Feb 2, 2017 at 2:42 PM
    #108
    BCJake
    BCJake [OP] Well-Known Member
    BC
    2016 Tacoma TRD OR AC MT QS
    -5100's all four corners, fronts set at 0 -888 OME coils, SPC UCA's, Deaver AAL -Driver's sidefront spacer -SCS 16" Ray10's in Matte Dark Bronze -255/85/16 Toyo MT's -Avid Off-Road weld on sliders -RCI Front Skid -SSO Slimline Hybrid front bumper, Smittybilt X20 Winch -Flipster V2 front plate bracket -FabFours Premium rear bumper -Front diff needle bearing delete, ECGS bushing in -Plasti dipped front grille -G-Tek Fab door sill guards -CaliRaised 2X2 Ditch Lights -ARB CKMA12 Compressor & Slee OffRoad Mounting Bracket -Shapeways 2 Switch Plate
    I can't speak to #2 as I just installed an AAL and don't have the drive line symptoms. The ECGS will definitely take care of the front. You're definitely in good hands at Dale's so I suspect a positive turn out all around. Let me know how she drives when they're done with it.
  9. Feb 2, 2017 at 2:44 PM
    #109
    0210
    Vancouver, BC
    Will do. I dropped it off early this morning and they just called me asking about the wheel lock key, so it sounds like they're just getting started and will likely have the truck for the rest of the day. Hoping I can pick it up in the evening. I got some good feedback in the driveshaft vibrations thread, and it sounds like I'll need to get shims for the leaf packs. Not sure who'll provide those or how this will work timing-wise, but fingers crossed I can get this resolved soon.
    BCJake[QUOTED][OP] likes this.
  10. Feb 3, 2017 at 2:27 PM
    #110
    0210
    Vancouver, BC
    Picked the truck up. ECGS bushing seems to have smoothed some things out, but I'm still getting crazy vibrations between 25 and 35kph. Doesn't matter whether I'm accelerating, braking, or cruising. That speed range is nuts, and the carrier bearing drop doesn't seem to have helped.
    Going to have the pinion angle measured on Monday and will then order shims based on the result. If shims don't do it, I think I'll have to get a one-piece driveshaft manufactured, as that seems to be a 100% solution.
  11. Feb 3, 2017 at 9:09 PM
    #111
    Markc1024
    Markc1024 Well-Known Member
    Throw on some Sumosprings and reduce the squat. I've got about .5 inches of clearance unloaded; 200 lbs starts to make contact. Same AAL setup
  12. Feb 4, 2017 at 11:35 AM
    #112
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    There's a recommend oil? I'm using toyota oem
  13. Feb 6, 2017 at 2:56 PM
    #113
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    rent them out, have them paypal you the amount to replace, and small fee to ship, then when they return them, you refund the money, it worked well for fender roller on lowered cars, allows a large group of people use the tools with only paying shipping back and forth, if they don't return, you have your money to replace.
  14. Feb 8, 2017 at 11:13 PM
    #114
    Hautian
    Hautian Well-Known Member
    Upper Peninsula, Michigan
    2016 Silver TRD OR - sold / 2022 4Runner
    I'm using Toyota oil as well, are we supposed to change? I just topped mine off after changing the bushing and seal.
  15. Feb 9, 2017 at 6:14 PM
    #115
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Looking for the uninstall tool
  16. Feb 10, 2017 at 8:44 PM
    #116
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    I topped it off with valvoline with the spec oil weight.
  17. Feb 10, 2017 at 9:03 PM
    #117
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I just got mine back from the last guy I lent it to. Send me a PM with your name and address and I'll let you borrow mine.
  18. Feb 11, 2017 at 7:02 AM
    #118
    AZBACKCOUNTRY
    Doug
    Pm sent
  19. Feb 11, 2017 at 2:16 PM
    #119
    bas0617
    bas0617 Well-Known Member
    Brad
    San Diego
    2017 TRD OR DCSB 4x4
    Fox 2.5 Coilovers Fox 2.0 RR Headstrong AAL SPC UCA 4Runner Wheels 275/70/17 KO2
    How much did a shop charge you for install?
  20. Feb 11, 2017 at 2:44 PM
    #120
    BCJake
    BC
    Price of ECGS Bushing+3 hours labour+change for replacing lost fluid during the swap. If you have time and decent mechanical aptitude, you cash save a bundle by doing the swap yourself. ECGS has a couple of good videos on their website that more or less show you what is involved.
