Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Feb 11, 2017 at 5:38 PM
    #121
    Markc1024
    Markc1024 Well-Known Member
    I'm debating this myself. I did an AAL in the rear to gain 1.5" and if I go over 1" in the front (Icon) the vibes seem to start. Prior to my lift, the passenger side was about 1/4" higher than the driver side. I've made several adjustments to both sides and so far it seem like if I keep the + 1/4" on the passenger side, that also seems to help keeps the vibes down. Beyond just the lift height, the angle of the front diff to the shaft seems to also be a factor. I really don't want to tear into it, and am not looking for a large increase in lift (prefer a 1" rake), but may have to eventually. For those on the fence, don't feel like you have to keep the left/right exactly level - it seems to help to allow for some variance.
  2. Feb 18, 2017 at 11:35 AM
    #122
    TRD69
    TRD69 Member
    2016 Tacoma TRD
  3. Feb 18, 2017 at 11:36 AM
    #123
    TRD69
    TRD69 Member
    2016 Tacoma TRD
  4. Feb 18, 2017 at 11:37 AM
    #124
    TRD69
    TRD69 Member
    2016 Tacoma TRD
  5. Feb 18, 2017 at 11:38 AM
    #125
    TRD69
    TRD69 Member
    2016 Tacoma TRD
    2016 Tacoma with a 2" leveling kit(just space over strut and skid plate spacers). I could hear a noise in the front at around 25mph. As described by another posting "a rythmic humm". Installed Drop Diff kit(again, just spacers). Noise still there. Dealer said to take the life out before they checked it out for warranty purposes. Removed the lift, noise is gone. Possibly I should have purchased a better kit. Does anyone know of a 2" leveling kit that wont cause that sound or another solution?
  6. Feb 18, 2017 at 11:39 AM
    #126
    TRD69
    TRD69 Member
    2016 Tacoma TRD
  7. Feb 18, 2017 at 11:39 AM
    #127
    TRD69
    TRD69 Member
    2016 Tacoma TRD
  8. Feb 18, 2017 at 11:40 AM
    #128
    Hautian
    Hautian Well-Known Member
    Upper Peninsula, Michigan
    2016 Silver TRD OR - sold / 2022 4Runner
    @TRD69 you just posted the same thing multiple times.
  9. Feb 18, 2017 at 11:42 AM
    #129
    Hautian
    To your question, if it is the needle bearing then it doesn't matter the brand of lift.
    BCJake[OP] likes this.
  10. Feb 18, 2017 at 11:51 AM
    #130
    TRD69
    TRD69 Member
    2016 Tacoma TRD
    2016 Tacoma with a 2" leveling kit(just space over strut and skid plate spacers). I could hear a noise in the front at around 25mph. As described by another posting "a rythmic humm". When in 4WD the noise is gone. Dealer said it's caused by the angle of the axle after the lift installation. Installed Drop Diff kit(again, just spacers). Noise still there. Dealer said to take the lift and diff drop out before they checked it out for warranty purposes. Removed the lift, noise is gone.
    After reading posts on this issue for hours I'm convinced the bushing is the answer. I know the dealer won't even consider this fix and will say it will void my warranty so I won't go back to them any more on this issue. I want the bushing installed so I can re-install the lift kit. I have a couple of questions though.
    1. Since I already have the diff drop kit, is there any benefit to installing it after I install the bushing and put the 2" lift/leveling kit back in the truck?
    2. Should I purchase and install the sway bar spacers as well just to complete the job?
    3. I'm not a mechanic but am mechanically inclined and did install the lift and diff drop myself . Installing the bushing...is this a typical DIY job or would you recommend taking it to a garage(not Toyota) to install it?
  11. Feb 18, 2017 at 12:01 PM
    #131
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I'm not one to lift my truck. I've always liked them stock which makes me fortunate because I'm not tempted to spend a lot of money on my truck.
    With that said, I've installed 2 ECGS bushings on stock Toyotas. Don't let the fear of installing the bushing keep you from doing what you want. It's a pretty easy install and it's cheap. It's nothing to be afraid of.
  12. Feb 18, 2017 at 7:03 PM
    #132
    Hautian
    It takes some time but it's not difficult if you're mechanically inclined. I would recommend a second set of hands though.
    I'd skip the diff drop.
    If you didn't notice your swar bar rubbing I would skip the brackets for now and see what you got after your lift goes back in.
  13. Feb 18, 2017 at 7:08 PM
    #133
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Just got the new bushing in. Will need to learn how to do it out plan to install soon.
  14. Feb 18, 2017 at 7:58 PM
    #134
    KilllerskunK
    KilllerskunK Active Member
    Craig
    2016 Tacoma TRD Off-Road(QuickSand)
    Memphis M class Speakers TRD Pro Shift knob with added quicksand colors Door Sill Protectors with quicksand color lettering TRD Pro Grill Tacoma Embossed Bed Mat Custom Fit Console tray Front windows tinted Dash Leter inserts(Quicksand) V6 emblem removed raised matte black letter inserts in tailgate
    I had the ECGS put in after my lift and it solved all my issues as well.
  15. Feb 18, 2017 at 10:04 PM
    #135
    Jepn2233
    Jepn2233 Well-Known Member
    Rock Hill, SC
    2018 Super White TRD Pro
    Are the seal, removal tool,and brg/race driver all required for this install?
  16. Feb 19, 2017 at 4:51 AM
    #136
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Has anyone ever installed one of these and discovered a problem caused by it. I am planning on installing my lift in a few weeks and though about doing this bushing. I hate to do them at the same time though because 1 I don't know if I'll actually need it. And 2 if any issues come up (like a vibration or whatever) It will be harder to pinpoint which mod made the problem.
  17. Feb 19, 2017 at 5:12 AM
    #137
    JoeCOVA
    Joe
    Colorado Springs
    I'm doing mine before the lift. As far as I know there have been no problems with it.
  18. Feb 19, 2017 at 5:15 AM
    #138
    ievko82
    WV
    I might just suck it up and do it at the same time also. I'd like to get the dimensions of the end piece of the bearing removal tool I plan to just make my own.
  19. Feb 19, 2017 at 5:20 AM
    #139
    Hautian
    Seal isn't necessary unless yours is bad but there is chance you will damage it so I would have a new one to put in.
    Someone on the forum used something like a blind hole pilot bearing remover with success. I just used the ECGS tool.
    Instead of the race driver I've read that you can use a socket turned backwards. You just need something flat the diameter of the bushing.
  20. Feb 19, 2017 at 5:44 AM
    #140
    JoeCOVA
    Joe
    Colorado Springs
    There is a tool being passed around the site. Just pay for shipping I think. Not sure who has it though.
