Front Differential Drain and Fill Plug Tool Sizes
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Aug 6, 2014.
  1. Aug 6, 2014 at 1:23 PM
    skeezix
    skeezix [OP] Well-Known Member
    Colorado
    1998 Limited
    I have a 1998 TRD. The drain and fill plugs in my front differential appear to be larger than the 10mm hex (allen) key that I have. Before I make a long trip to purchase a 12mm hex key, I'd really appreciate it if somebody please verify that a 12mm will work and if not, then what size do I need??
  2. Aug 6, 2014 at 1:34 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I think the fill is 10mm and the drain is 12mm
  3. Aug 6, 2014 at 1:37 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Shit is hard as hell to get off. You will need an extention to get more torque. Also helps if you get some compressed air and spray it upside down on the plug to freeze it. I put an entire can on mine.
  4. Aug 6, 2014 at 3:59 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I think part of the japs revenge plan for us nukeing them involved the design of the front diff fill plug on the taco. Its an enormous pain to get off and even hard to do without stripping it out. Its almost easier to fill it through the vent tube!!
  5. Aug 7, 2014 at 12:13 PM
    skeezix
    Colorado
    1998 Limited
    Tool size for the fill plug is ten millimeters, tool size for the drain plug is twelve millimeters. I've found various specs for the torque on the various drain and fill plugs, so I just torque everything to 30 pound-feet.
  6. Apr 28, 2016 at 11:24 AM
    OverlandArmory
    OverlandArmory Member
    Nick
    1998 Toyota Tacoma
    Where is the front fill plug? I see the drain plug, but can't seem to find the fill. May be all the mud caked everywhere :rolleyes:
  7. Apr 28, 2016 at 1:47 PM
    MattFL
    MattFL Well-Known Member
    S. Florida
    1999 Tacoma V6 4x4 TRD Extended cab
    Fill is on the front of the diff. My drain plug has been stuck for years, twisted my Allen socket trying to remove it. So I use an oil extractor and just suck the oil out through the fill plug, then fill it back up.
  8. Apr 28, 2016 at 5:14 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I did mine after I bout my 2004 and it must have been tightened by Hercules himself. Fack was it ever tight, it started to strip (drain bolt) and then I said a few prayers and re grouped and bam it broke free. Had a large box end wrench for leverage over the end of my ratchet, it was bending the wrench.
    Put synthetic in and hope you sell it before you need to do it again. What a pain, the trans, transfer case, and rear diff were sooooooo much easier!
  9. Jan 23, 2019 at 2:24 PM
    darcycook
    darcycook Well-Known Member
    2005 4x4 Toyota Tacoma
    i found a removal tool when Allen is strip out fill and drain is 10mm wide site is KAON.COM.AU this is amazing tool and a socket head replacement puog
  10. Jan 23, 2019 at 7:58 PM
    thenodnarb
    thenodnarb Well-Known Member
    California
    2001 TRD 4x4 379k and counting
    i just did this on my 01 and both drain and fill were 10mm. seems like some people's trucks are 10 and 12.
    10mm is commonly sold at parts stores but i had to go hunt for a 12mm and didn't even need it.
  11. Nov 18, 2020 at 7:55 AM
    Mtnm
    Mtnm Member
    Colorado
    2001 Tacoma TRD
    T55 fits better than 10mm (2001 Tacoma TRD). Once out I could see it really is a T55. I did get both out with a 10mm, but once out it clearly takes a T55. Wonder if that is why everyone complains about rounding problems? Plan on a long breaker bar (30"?).
  12. Nov 18, 2020 at 7:57 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I used a torx too when mine started to strip. Much better grip, had to hammer it in though.
    Mtnm likes this.
