Front differential fluid change question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gregzz, Jan 26, 2020.
  1. Jan 26, 2020 at 8:06 AM
    gregzz
    gregzz [OP] Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    Hey all!! I changed my front differential fluid on my 2011 Toyota Tacoma TRD 4X4 last weekend and this weekend I just looked underneath just to Make sure I have no leaks to be safe and I see I have a little oil coming out from around the upper fill plug and I might possibly have some leaking around where the front drive shaft goes in. I’m wondering if I used too much fluid (I filled it until it dribbled out and put the upper bolt back in and tightened it down) so now I’m paranoid that I have a leak possibly? Maybe?? I read that I’m supppsed to fill it until it lightly dripped out which is what I did but I also didn’t change the crush washer either so?? Any advice is apreciatted. Thx guys!!
  2. Jan 26, 2020 at 8:17 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Nah, you should be good to go. For a bit of piece of mind, pick up another crush washer and reinstall the fill bolt. More than likely, the crush washer you used was bad or the fill plug wasn't torqued to spec. At least it's the fill plug and not the drain plug, otherwise you'd be in for another 2ish qts of gear oil as well.
    -J
    gregzz[OP] likes this.
  3. Jan 26, 2020 at 8:25 AM
    gregzz
    greg
    las vegas nv
    Awesome. Thank you!!
  4. Jan 26, 2020 at 12:14 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Teflon tape.
    fixnfly likes this.
  5. Jan 26, 2020 at 12:16 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    New crush washer. Proper torque.
    gregzz[OP] and BillsSR5 like this.
  6. Jan 26, 2020 at 1:44 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Filling it can be messy, wipe it clean and check later.
    gregzz[OP] and Blockhead like this.
