Front differential non ingaging ?
Discussion in '1st Gen. Builds (1995-2004)' started by z71bowhunter, Dec 1, 2021.
  1. Dec 1, 2021 at 12:02 AM
    z71bowhunter
    z71bowhunter [OP] Well-Known Member
    Randy
    Temple,Ga
    96 Tacoma Ex-Cab 4x4
    I got a 1996 Tacoma 4x4 as you can see in my avatar.I recently had a motor swap done,now my front differential is not ingaging.I would notice before when I shifted the floor lever in 4wheel low,my green lite would come on dash.I checked my 4WD fuse,fine,looked under truck,noticed there are 2 plugs that is connected to the transfer case.Could this be a electrical issue?Fluid level works off transmission fluid correct? Everything worked fine before motor swap,,,HELP.
  2. Dec 2, 2021 at 11:49 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm guessing your truck has a J shift transfer case. If this is the case there are only sensors in it telling the ADD actuator to engage or disengage. I don't have any experience with the vacuum actuated ADD but that could be your issue.
  3. Dec 4, 2021 at 4:32 PM
    z71bowhunter
    Randy
    Temple,Ga
    I got my vacuum situation fixed,I am getting vacuum to the actuator. When I pull the shifter and move it over to the neutral position,my green 4whell light will flicker on dash and I can here a clicking noise like a relay?
