Front differential oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cj15, Jun 15, 2022.
  1. Jun 15, 2022 at 8:02 AM
    cj15
    cj15 [OP] Active Member
    Completely a newbie on this subject. For the limited search I've done, it seems there are two halves of the front differential when replacing the diff oil, a driver and passenger side. I just did the clamshell bushing replacement obviously on the driver side and I'm thinking this is the side I will be draining and replacing the oil. I see two hex nuts, bottom for draining and the top for filling. Can someone confirm the two halves? I assume same oil type.
  2. Jun 15, 2022 at 8:06 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm a bit confused.
    Yes, though. The front diff is called the clamshell due to its shape and vertical split line. It is one integral unit. Draining and filling from the left side is all that you need to do.
    Same gear lube as the rear diff.
    33yrsoftoys, jmneill and Tacospike like this.
  3. Jun 15, 2022 at 8:07 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    The two halves is considered one unit. Only one drain plug and one fill plug.
    geo8866 likes this.
  4. Jun 15, 2022 at 8:11 AM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    davidstacoma likes this.
  5. Jun 15, 2022 at 8:12 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Make sure to get a proper hex socket/bit.
    Remove the fill plug 1st.if successfull, move to drain.
  6. Jun 15, 2022 at 8:53 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Do those front differentials still take about a 1 1/2 qts?
  7. Jun 15, 2022 at 8:56 AM
    dr4g1116
    Just about.
  8. Jun 15, 2022 at 9:34 AM
    cj15
  9. Jun 15, 2022 at 1:12 PM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
  10. Jun 15, 2022 at 3:39 PM
    geo8866
    geo8866 Unknown
    2019 TRD Sport cement
  11. Jun 15, 2022 at 3:59 PM
    zoo truck
    None
    Even those cheap outboard engine lower unit pumps work very well for pumping gear lube in these differentials, and transfer cases.
  12. Jun 16, 2022 at 6:52 PM
    cj15
    I bought a similar transfer pump from Harbor Freight.
    Someone asked about the clamshell bushing that I have installed. For clarity, I replaced the needle bearing with the East Coast Gear Supply 8 inch clamshell bushing.
