front differential question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by now151, Dec 19, 2013.
  1. Dec 19, 2013 at 3:45 PM
    now151
    now151 [OP] New Member
    parsonsburg
    tacoma
    6" lift kit suspension
    I am installing a 6 " lift kit on my 05 Tacoma . I've disconnected the drive shaft from the front differential and still have the cv axles in place and didn't have to remove them, just supported them. got my new mounts for the diff in place and bolted to the diff. my question is, is there anyway something could come loose inside the diff from disconnecting the drive shaft? the reason I ask is because when I turn the diff by hand where the driveshaft mounts, the drive axles don't spin. I don't know if this is a problem or normal. hoping someone here has a comment?
  2. Dec 19, 2013 at 3:48 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    The axles won't spin if you turn that end of it unless you have 4WD engaged. Should be normal.
  3. Dec 19, 2013 at 3:48 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    The Automatic Differential Disconnect(ADD) is not connected in 2wd
  4. Dec 19, 2013 at 4:22 PM
    now151
    parsonsburg
    tacoma
    thanks for the replies, I didn't think anything could have come loose in the diff. from disconnecting it. so the add actuator disconnect all gearing. does anyone know where I could get a diagram of a Tacoma front diff. break down?
  5. Dec 20, 2013 at 8:26 AM
    now151
    parsonsburg
    tacoma
    thanks for the TIS info. ordered me two days worth. very informative
  6. Dec 20, 2013 at 1:08 PM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Good luck with the lift op
