front differential side bearing replacement.. done!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Metallikatz3, Dec 27, 2010.
  1. Aug 11, 2011 at 11:16 AM
    #141
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    When I pull my driver side CV if the needle bearings fall out I'll replace. Otherwise I'll probably leave it as is. The new wheel bearings made my truck quiet and smooth as glass.
    Refer below
  2. Aug 11, 2011 at 1:55 PM
    #142
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Thanks for your post. You obviously know what you're talking about. Keep us posted if you make any progress with your regional Toyota rep.
  3. Aug 27, 2011 at 10:33 AM
    #143
    Jamco6000
    Jamco6000 Member
    Louisiana
    06 4x4 OME 3inch
    Finished this repair this weekend. I rented a pilot bearing removal tool that attaches to a slide hammer, worked like a dream. Whole install was maybe 5 hours by myself. Only thing that gave me trouble was getting the cv back in. 130000 miles loosened things up tho. Let me know if anyone has any questions while things are still fresh.
  4. Aug 27, 2011 at 12:37 PM
    #144
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    How bad were your vibes? mine are getting bad. from 5-45mph and constant cyclic vibe during low speeds.
  5. Aug 29, 2011 at 2:11 PM
    #145
    bradpenton
    bradpenton Well-Known Member
    Birchwood, TN
    TRD Sport 4WD
    Has anyone got a recent quote on changing the drivers side axle bearing and seal from the dealership. Ive got what seems to be a good bit of slack in that bearing. Not making any noise yet but i have a vibe from 55-60.
  6. Aug 29, 2011 at 4:21 PM
    #146
    Dark Knight
    Jeff
    NC/SC
    Dealer wants about $700 for doing one wheel bearing so I would imagine it would be close to the same price range??
  7. Aug 29, 2011 at 4:27 PM
    #147
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Where did you rent the pilot bearing tool from?
  8. Aug 29, 2011 at 4:30 PM
    #148
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Good luck finding a dealership that will change the bearing from the outside. They want to follow the FSM and tear down the whole front diff to get to it, at which point they'll tell you it's cheaper to swap out the whole front diff with a new one. Cost for that is about $2,200.
    I rented mine from O'Reilly's (formerly Kragen around here). They had the pilot bearing removal tool that fit their slide hammer.
  9. Aug 29, 2011 at 4:31 PM
    #149
    BenWA
    Boston burbs
    If we are talking about dealerships, I haven't found one that is willing to do a rebuild of the front diff -- all the ones I've talked to said that Toyota dealerships have to replace the whole diff (upwards of $2200).
    Now a small mechanic shop may do it for around $700-800 if it is a 5 hour job.
  10. Aug 29, 2011 at 7:23 PM
    #150
    05Moose
    Jim
    ywen had an independent shop do it for around $500 IIRC. They replaced the bearing without removing the diff. Can't remember which thread he posted that in...maybe it was the deleted Krookz thread?
  11. Aug 30, 2011 at 2:49 AM
    #151
    bradpenton
    Birchwood, TN
    TRD Sport 4WD
    I believe i can get the suspension out of the way pretty easy, Once thats done and the wheel side of the cv axle is loose, Does the axle simply slide out from the housing? Is there any reason other than lost needle bearing for me to open up the diff housing? Ive replaced bearings before but never on a front end.
  12. Aug 30, 2011 at 7:01 AM
    #152
    05Moose
    Jim
    Axle doesn't just "slide out". Mine took an experienced person awhile to get it out with a lot of hammering/swearing.:D It had to be pried out with a crow bar and still hammered on with a small sledge hammer. I wanted to see how you get one out and it was a challenge on mine. Now unlike Jamco, the new one slid in easily (I thought we would have to pound it in but it almost just slid in after a little finagling).
    And I wouldn't worry about losing the needles inside the diff. If you are worried, stuff something like a sponge behind it first to keep anything from going inwards. And have an extension magnet handy just in case. Aside from that rare possibility that they fly back in far enough to become a problem, there's nowhere else for those needles to go. The bearing is right at the edge behind the seal.
  13. Aug 30, 2011 at 7:41 PM
    #153
    Jamco6000
    Jamco6000 Member
    Louisiana
    06 4x4 OME 3inch
    sorry guys, been out of town,
    @Dead Bolt
    It got to the point where it was making the vibe at most any speed. 5 to 45 pretty bad.
    @bradpenton
    dealer wants 2300 to change it because they just change the whole diff.... stupid i know
    @BenWA
    I rented the pilot bearing removal tool from Autozone. It fit their slide hammer.
    @bradpenton
    the axle doesnt just slide out, there are special groves machined into the axle that are designed to place a pry bar on and hammer it out. It is a PITA and the hardest part in my opinion
    with the pilot bearing removal tool you shouldnt have any problem with the needle bearing falling out. it took maybe 5 good wacks to get it to come out.
    @05Moose
    it was my fault the cv didnt go in easily, i took the snap ring off cause it was preventing me from getting it in, then i realized it was supposed to be on there,:facepalm: but with another beer down the hatch everthing worked out well. Sept for that damn dust shield that i hate, i can never get it to not rub the rim.
    my email is jamco6000@gmail.com feel free to email, i have some pics but it was dark during the gritty part
  14. Aug 31, 2011 at 9:13 AM
    #154
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    Hey just wanted to give everyone an extra idea on removing the axles. If you use the slide hammer with a small hook to get in the slots on the inside part of the cv. Then take a large hose clamp to hold it in the groove. It should only take a few good solid wraps with the slide and it should be out.
  15. Sep 1, 2011 at 5:38 AM
    #155
    bradpenton
    Birchwood, TN
    TRD Sport 4WD
    Haynes manual say it should come right out with the slide hammer. Good idea using the hose clamp to keep it from slipping out. Gonna give it a shot this weekend. Let you know how it goes.
  16. Sep 29, 2011 at 4:27 PM
    #156
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    :popcorn: My 2011 with 4600 mi on it started doing the vibe - 5-40mph sounds about right. It of course started right after I put the 5100's with an Eibach spring at the stock setting. Net lift is 1.6" up front. Like all others it goes away in 4hi. Its barely noticeable and I know the dealer will say its normal. Especially beacuse the duratracs make some noise BUT again in 4hi its noticeably smoother. WTF I dont just have a new Diff I have a new truck. I'll be taking it in for my free oil change and will bring it up and expect no help - they will either tell me cant feel it or its the lift causing it! This is such BS! I've had Ford, Chevy, and a 99 Tacoma 4x4 with lifts and never had an issue like this. It's bugging me more and more now. I may have to put the stock wheels and tires back on because they are much quieter so the problem will be more noticeable :confused:. :mad:. I want to move the front shocks to the .85 setting but this problem will get worse I'm sure.
  17. Oct 4, 2011 at 12:42 PM
    #157
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    So my truck started to experience some front end noise, it almost sounds like a rock is stuck between the Dust shield of the brake and rubber is grinding. There is also a pinging noise and now I have a whirl and can feel it in my tires. I have a feeling its this diff bearing stuff. I thought it might be my CV axle but everything looks fine, no rips or leaks anywhere. I have a 3 inch lift that I have been running for about 4 yrs with a drop kit and my angles are almost perfect. I'm stumped! I took it to the Toyota Dealership and in 4 hrs they told me it was my belt tensioner and it would cost me around $500 to replace. I say BS, supposedly they had their number one tech look at it and that's what he thinks it might be........they want more time with my truck.
    I came across this thread and this makes sense to me. BIG question, if I do this do I really have to get a new CV axle......can't I just sand it down a bit if it has those small groves and what side does the bearing go in.....drivers side or passengers. I think the noise is coming from the passenger side.
    Also, should I check my wheel bearings first?
    Thanks!
  18. Oct 15, 2011 at 8:15 AM
    #158
    06SUPERWHITE
    06SUPERWHITE Member
    Carl
    Barrie Ontario Canada
    06 Access Cab SR5 3" lift
    3" lift after market rims 285/75/17" tires dual side exit cat back exhaust, k&n cold air,
    Im planning on doing this next weekend. Has anyone had the problem return after doing the repair? How many miles between?
  19. Oct 19, 2011 at 9:02 AM
    #159
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    If you can take pictures of the entire process.
  20. Oct 21, 2011 at 7:24 AM
    #160
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i'm subscribing just because i plan on lifting my truck next year. this will be an excellent thread to have handy
