front differential spacer question
Discussion in 'Suspension' started by ultraman69, May 15, 2008.
  1. May 15, 2008 at 6:27 PM
    ultraman69
    ultraman69 [OP] Member
    calgary alberta canada
    08 tacoma dbl cab trd
    hi i am not a mechanic.....i have no idea what a front differential looks like but i am trying to put the spacer drop in that came with my kit.....does anybody have a clear picture to show me
  2. May 15, 2008 at 6:45 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    first major question to make sure we're all on the same page....ur a 4x4, right?
  3. Aug 30, 2008 at 9:31 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    If you aren't 4x4 what options do you have in the front to decrease the harsh CV angles?
  4. Aug 30, 2008 at 9:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you are a PreRunner and are worried about your CV angles, have no fear! There arnt any on a PreRunner. :D
  5. Aug 30, 2008 at 9:34 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    NICE! except i was hoping for another cool mod. :mad:
  6. Aug 30, 2008 at 9:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, putting a diff drop on a PreRunner is much more involved than on a 4x4, as you have to add a differential to the front. Then a drive shaft, transfercase, etc.. :)
  7. Nov 4, 2008 at 10:03 PM
    alexamado
    alexamado TEXMEX TACO
    TEXAS
    2006 PRERUNNER TRD SPORT
    885 OME Coils w/ OME N140S Shocks, Rear TSB w/ Rear AAL, Rear 5125 Bilstein Shocks, Westin Ultimate Bull Bar w/ KC Slimlites, Westin Running Boards, Roll n Lock Retractable Bed Cover, AVS Bugflector II
    so if i have a non-4x4 trd sport taco and plan on putting a 3'' toytec lift....i don't need the front differential??? I do plan on getting the shock extenders but i've read on other forums that i don't need a newer uca. Is that true???
  8. Nov 5, 2008 at 7:13 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    This thread makes my head hurt.
  9. Nov 5, 2008 at 7:15 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    OK, so first, I need to make it into a 4x4? then I need to get those fancy mud flaps?
  10. Nov 5, 2008 at 7:15 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    That would be a sweet mod!
    Be sure to do a write-up with plenty of pictures! :)
  11. Nov 5, 2008 at 7:17 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    A diff. is what makes your truck 4x4. You don't have that so you don't need to drop it, nor do you need the UCA's as you don't have CV joints.
  12. Nov 5, 2008 at 7:20 AM
    The_Hodge
    SC
    the uca's play a big part in getting the alignment perfect, not just cv angles
  13. Nov 5, 2008 at 7:22 AM
    mjp2
    NJ
    The UCAs help with alignment issues regardless of the drivetrain. I'd recommend them if you're going for 3" of lift, but they're not a requirement.
  14. Nov 5, 2008 at 7:24 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I can be taught, sorry alexamando, my appologies.
    I have a 4x4 and don't have aftermarket UCA, thus far no alignment problems.
    Thanks Hodge and MJP
