Front differential TSB coming soon??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMAY25, Jun 3, 2011.
  1. Jun 3, 2011 at 5:48 PM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    '06 double cab TRD off road
    I took my truck in due to the front end growl/vibration that goes away in 4hi this morning. The tech told me that Toyota is aware of the problem with the front differential and that a TSB is in the process of being established. Anyone else heard this?
  2. Jun 3, 2011 at 6:30 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    Would be nice, but I have some doubts until I see that TSB ...
  3. Jun 3, 2011 at 6:34 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You have a 2006? Are you hoping to get it fixed before the powertrain warranty expires?
  4. Jun 3, 2011 at 6:51 PM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    I was told that since I came in with the complaint prior to my warranty expiring I would be covered beyond the expiration date.
  5. Jun 3, 2011 at 6:54 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Get that in writing from the dealer now.
  6. Jun 3, 2011 at 6:54 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    ^^ Better get that in writing...from the owner of the dealership.
  7. Jun 3, 2011 at 7:00 PM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    Plan on it when I return on Monday. An employee backed into my truck while in service causing damage to the driver bedside
  8. Jun 18, 2011 at 9:19 AM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    I now have it in writing.
  9. Jun 21, 2011 at 10:14 AM
    wlmuncy
    William
    Knoxville, TN
    ^^^^Good man^^^^.
  10. Jun 21, 2011 at 10:16 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Is that what that is? I couldn't place it. Is it only in 2hi? I got the throw out bearing tsb done and its still there...
  11. Jun 21, 2011 at 10:33 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    What dealership? I might have to drive down there before I hit 60k
  12. Jun 21, 2011 at 11:21 AM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    Springfield IL. The tech is supposed to get back to me as far as when the TSB is expected. I showed him a copy of the TSB out on the Tundra for the same issue and that is what caused the tech to fully understand my complaint.
  13. Jun 21, 2011 at 11:28 AM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    It is only in 2hi, most noticable between 35-40 mph. It goes away as soon as you flip it into 4hi.
  14. Jun 21, 2011 at 11:47 AM
    DWreck
    Derek
    Las Vegas, NV
    That's mine! Sweet! I know what the frick it is now.
  15. Jun 21, 2011 at 12:03 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    Interesting... I feel a growl/vibe maybe like you're talking about but hadn't figured out if it was front or rear--makes sense now. I also noticed at last oil change that the front diff is weeping around where the left halfshaft exits. Not a real leak, just a weep on the diff housing itself. Any of you notice this and you think its related?? It doesn't seem like enough fluid to cause a problem, but never know?
  16. Jun 21, 2011 at 12:54 PM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    Not sure about that. You will notice the vibration through the gas pedal/floorboard.
  17. Jun 21, 2011 at 12:59 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    its the needle bearing in the front carrier assembly. It is the bearing that allows the CVs to rotate freely when in 2wd. When you go into 4WD you drive the carrier and the CV now moves at the same speed as the carrier and the bearing is no longer rotating. this is why it goes away. the problem only happens on the drivers side because the CV goes directly into the carrier assembly and the needle bearing on this side. Higher CV angles from lift does cause this to happen faster. the passenger side is not an issue because there is an intermediate shaft that rides on the needle bearing and not the CV directly.
  18. Jun 21, 2011 at 1:11 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    ^^Nice summary, PRS2TiFJ, thanks. Do you think the dealer will make a stink about a 0.85" 5100 lift and claim the warranty is void? And is it a critical issue once you feel the wear? I would imagine any bearing assembly going bad is not going to suit the diff very well...
  19. Jun 21, 2011 at 1:12 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    And thanks, JMAY25. I think this is the same groan I feel, though it's not terrible. Did yours start mild and progress, or was it pretty static?
  20. Jun 21, 2011 at 1:15 PM
    DWreck
    Derek
    Las Vegas, NV
    Yes!
    I noticed mine before lift and it was documented.
