Front differential TSB coming soon??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMAY25, Jun 3, 2011.
  1. Jun 21, 2011 at 1:27 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    Had mywhole front diff assy replaced, was making growling bearing noise only in 4hi at certain speeds, noise would come n go like a harmonic noise depending on the speed. Talked to the Toyota field rep, said bearings do go out for some reason. Was replaced immediately. I replaced it, got paid for it. Cuz im a tech for a dealership lol. U don't have to wait for a tsb. If they can reproduce symptom/sound then as long as its still under warranty they should replace it just like any other warranty issue
  2. Jun 21, 2011 at 1:33 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    Thanks tacobo670. Especially with your knowledge of things, do you think the 0.85" lift will be an issue with the dealer and warranty? I could drop it back to stock before going in, but would like to avoid that extra work if it's not a big deal. Thanks for any insight you can give...
  3. Jun 21, 2011 at 1:52 PM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    '06 double cab TRD off road
    My bilsteins are set at 1.75. I noticed it right after it was lifted. I was told that there was no way the lift was the cause.
  4. Jun 21, 2011 at 1:56 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    ^^Awesome, thanks. So no mention of the lift at the dealer? Surely they weren't the ones who said there was no way the lift caused it, right? That's very un-dealership-like...
  5. Jun 21, 2011 at 2:06 PM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    Interesting. I was told a new part (the front carrier assembly?) would be coming out with the TSB. I've read on here about others who have the differential replaced, only to have it happen again. Does that make any sense Tacobo670?
  6. Jun 21, 2011 at 2:09 PM
    JMAY25
    JMAY25 [OP] Member
    central illinois
    I told them I knew the lift wasn't the cause and they agreed.
  7. Jun 21, 2011 at 2:25 PM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    This has happened everytime I wheel my truck replace the seal and it stops leaking till the next time. I think what happens is mud gets in behind the dirt shield and just keeps packing in until it pushes the seal in past the larger section of the axle(where its supposed to seal) and then it leaks. Currently doing it for the third time lol. Does anyone else ever have this problem after wheeling their trucks?
  8. Jun 21, 2011 at 2:32 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Hey Ray! You wanna do mine at same time as my 25k?
  9. Jun 21, 2011 at 2:55 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Not saying the lift is the cause, but it can accelerate the failure or help it to show up.
  10. Jun 21, 2011 at 5:53 PM
    tacobo670
    Ray
    Las Vegas
    idk guys... wat the rep told me was that its just the bearing has a design flaw that makes it wear prematurely regardless of lift. its that over time the bearing just gives out n begins to shit itself (CUZ THERE'S TOO MUCH POWER FOR IT TO HANDLE!!!!) LOL jk. i think we should file a lawsuit for toyota saying that we get stranded when we out wheeling n have them pay us a bazillionmillion dollars for our suffering. imo. lol
    jump it, crawl it, bogg it, slide it, smash it, roll it, 4WD ride it till it breaks! bring straps.
  11. Jun 21, 2011 at 6:08 PM
    DWreck
    Derek
    Las Vegas, NV
    WINNING!
  12. Jun 21, 2011 at 6:40 PM
    dtacow
    dtacow Well-Known Member
    TSBs piss me off because they are all design/build related, yet expire along with warranty. Those with 2005, 2006 etc. are Sh_t Out of Luck. Toyota needs to improve their design/testing of their vehicles before I buy another one.
  13. Jun 21, 2011 at 6:43 PM
    tacobo670
    Ray
    Las Vegas
    imo, thats y i waited for a little bit when the new models came out so they can work out the bugs (most of them i guess). but then if u get the extended warranty u dont got much to worry about
  14. Jun 21, 2011 at 6:43 PM
    DWreck
    Derek
    Las Vegas, NV
    As long as it is documented that you had the issue while you still had a warranty they should recognize it
  15. Jun 21, 2011 at 6:45 PM
    #35
    tacobo670
    Ray
    Las Vegas
    word.
  16. Jun 21, 2011 at 7:47 PM
    #36
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    I am glad I did not get the extended warranty, it would have been a waste of money.
    (Extended warranties are a waste of money by definition).
    But I did get this diff issue documented way before even my 3yr/36K mile warranty expired. I'd be all over a TSB!
  17. Jun 22, 2011 at 10:38 AM
    #37
    dtacow
    You're missing the point:rolleyes:
    The bugs/kinks, whatever you call them should be worked out prior to final production.
  18. Jun 22, 2011 at 11:09 AM
    #38
    DWreck
    Derek
    Las Vegas, NV
    Never are with any manufacturer. That is why everyone has recalls and TSBs. Manufacturers don't test vehicles for thousands and thousands of miles. Therefore, most issues come up after testing. These manufacturers rely on the consumer (us) to inform them of these issues. Once enough consumers have had similar issues, they then look into it further and find solutions. If it was the way you want it, 2008 vehilces would just now be hitting the showroom floors!
  19. Jun 22, 2011 at 11:46 AM
    #39
    dtacow
    Then TSBs should not expire. They should be performed on the truck no matter what the age/mileage-- because they are design flaws. They should be tied to the VIN # and performed once on the truck.
    The fact is, Toyota doesn't fix recurring problems. Sloppy steering columns and weak rear suspension are two examples that show up on different models year after year (actually decade after decade). Poor frame rust proofing is another.
    Unique to the 2nd gen Tacoma-- poorly designed frame at the engine mounts, tinfoil tailgate.
    Maybe the models should be cheaper then for the first 3 years after they come out????
    Edit: You've made another point-- Toyota is not really a rung above other automakers.
  20. Jun 22, 2011 at 12:19 PM
    #40
    DWreck
    Derek
    Las Vegas, NV
    i agree completely! TSBs should be tied to the vin as they ARE technically a recall, minus the safety issue! As for the frame rust issue, I live in Vegas so......I don't get frame rust. :p I also agree with you on the tailgate issue. That is mearly a "Trying to make the vehicle lighter" thing. Sure it sucks, but then again, every manufacturer is doing it....
