Front differential TSB coming soon??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMAY25, Jun 3, 2011.
  1. Jun 24, 2011 at 5:57 PM
    #61
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    go wash ur laundry, wash dem skid marks out ur underwear
  2. Jun 24, 2011 at 6:16 PM
    #62
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I'd recommend TIDE COLDWATER! It's more economical!
  3. Jun 24, 2011 at 7:07 PM
    #63
    JMAY25
    JMAY25 [OP] Member
    central illinois
    '06 double cab TRD off road
    That sounds sexual
  4. Jun 24, 2011 at 7:21 PM
    #64
    tacobo670
    Ray
    Las Vegas
    with some OXY Clean!! Go Billy!!!
  5. Jun 24, 2011 at 7:40 PM
    #65
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Will this tsb include the 4runner? I just bought a 06 with 57,000
  6. Jun 24, 2011 at 7:43 PM
    #66
    tacobo670
    Ray
    Las Vegas
    i dont think so.
  7. Jun 25, 2011 at 4:09 AM
    #67
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    Has anyone done a write up on how to replace this bearing? And maybe have a part # for the bearing? I'd like to replace it and see if it doesn't fix my axle seal leaking. I've had my truck about 10000 miles and have replace the seal 3 times to try and stop the leak but it just keeps on drippin.
  8. Jun 25, 2011 at 9:59 PM
    #68
    DWreck
    Derek
    Las Vegas, NV
    Let someone else do it and see if there's a different outcome.
  9. Jun 25, 2011 at 10:19 PM
    #69
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    Yes, do a search, there are a bunch of threads on the topic. Look for Metallikatz's side bearing replacement thread.
  10. Jun 26, 2011 at 7:17 AM
    #70
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  11. Jun 26, 2011 at 10:27 AM
    #71
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Had to comment. The 2nd Gen has been out since 2005, and it still has a bunch of goofy issues. Toyota needs to step up their game.
  12. Jun 28, 2011 at 7:24 AM
    #72
    pootermobile
    Florida
    Thanks for the link Moose. I guess i'll have to try replacing this bearing and possibly the cv shaft too. I do remember seeing hot spots and shiny/smoothe spots on the 'bearing race' part of the cv. If its only 50 bucks I might as well just replace it. Thanks for all the info guys!
  13. Jun 28, 2011 at 11:11 AM
    #73
    BenWA
    Seattle @ 0.9 Mach
    If you do the replacement be sure to post your results. Would be nice to gather the results of as many DIY replacement experiences as possible here on TW.
  14. Jul 18, 2011 at 9:11 AM
    #74
    SLC TACOMA
    SLC TACOMA Member
    Tim
    SLC, UT
    08 4x4 DC, LB TRD SPORT
    5100's, 1.5 Block, LEER TOPPER, Winter=Blizzack on Stockers Summer=TBD
    Backed my truck out of the driveway yesterday and heard a metallic popping sound when I turned the wheel either way. Sound is coming from the left front wheel well and it kinda sounds like a CV joint that went on one of my older cars. I'm just really hoping that I don't have the 1st catastrophic bearing failure = $$$$$......
    Truck is going into the shop that installed my 5100's Wed morning... Not driving it till then..
    FWIW- 5100's are set to 2.5 and I had them installed in February. Since then I've put about 5,000 miles of EASY driving on the truck. 40k on it now.
    Any armchair mechanics have some E-spec for me?
  15. Sep 29, 2011 at 3:48 PM
    #75
    theturbodog
    theturbodog New Member
    I've got this same issue, well out of warranty before I purchased. Not really interested in more of the same parts so I'm thinking this is a good excuse to get an ARB Locker. I can't tell from the exploded diagrams I've found floating around, but it seems like the ARB would replace the needle bearing and everything around it. Anyone know for sure or solved their vibration with a new diff?
  16. Oct 10, 2011 at 9:57 AM
    #76
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Resurrection to see if an ARB would help with this problem? Maybe carry the axle differently? I was planning an ARB for the rear but if it solves the problem maybe the front will be earlier on the list. I have 10k on mine and have started getting the intermittent vibe..... DAMN!!
