Front differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IowaDucknDeer, Feb 7, 2020.
  1. Feb 7, 2020 at 5:50 PM
    IowaDucknDeer
    IowaDucknDeer [OP] Member
    Curt
    2007 tacoma
    ****Update: shop said bring it back and we will see what’s going on. Get a call this morning and the shop owner says the front seal on the transfer case is leaking. Quotes a price of about $200. Mind you I can't raise my arm from shoulder surgery so doing it myself is out of the question. I ask if there was any sign of it leaking when I brought it in, "No". I said I drove it home 20 miles, all highway and get home and it is leaking, that is questionable. He states that they didn't do anything with the transfer case. I ask if they took the front drive shaft out to replace the differential? "No. It rested on the cross member." I asked how did they get the differential out without taking out the front cross member.... "Well there's not much weight there, so it hanging couldn't have broken the seal. I really don't think that we caused it but I can't rule it out."
    Bottom line they are replacing the seal. I agreed to pay $100 as I can't prove they caused it and he can't prove they didn't.*****
    Let me start with I’m not a mechanic and I recently had shoulder surgery so replacing my front diff myself was out of the question. I had a local (and I hear a solid, reputable shop) replace it for me. New OEM front diff.
    Driving it home, it felt and sounded “off”. The RPMs never got above 3k even at highway speed but it felt and sounded like it was wound up much higher. I pull into the drive and hear a thud. Get out and look underneath the truck and the transfer case looks to be leaking and looks like there is fresh TC fluid all over the underside all the way back to the rear axle.
    Looking for some advice. I’ll be calling the shop in the morning.
  2. Feb 7, 2020 at 5:52 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Yikes. Could be a bunch of things wrong with the install. Hopefully they'll stand by their work and set it right.
    lynyrd3 likes this.
  3. Feb 7, 2020 at 6:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d go out and see if you can turn the front drive shaft in 2WD.
    Maybe the A.D.D or Transfer case is stuck?
    lynyrd3 likes this.
  4. Feb 7, 2020 at 6:09 PM
    IowaDucknDeer
    Curt
    2007 tacoma
    There is 12 months 12k mile warranty on parts/labor.
  5. Feb 7, 2020 at 6:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    Have the shop tow it back and fix it.
    lynyrd3 and TnShooter like this.
  6. Feb 11, 2020 at 8:46 AM
    IowaDucknDeer
    Curt
    2007 tacoma
  7. Feb 11, 2020 at 2:33 PM
    IowaDucknDeer
    Curt
    2007 tacoma
    I’ve got a new frame and without a doubt you can take out 4 bolts and remove the center portion of my frame crossmember. It would make the job of removing the differential much easier and I think they did.
    I just picked the truck up and the speedo wasn’t working and check engine light was on. Turns out they were running it in gear on the lift to get it to leak. That sent error messages and shut off Speedo and ABS.
    They fixed it but come one. They just keep creating problems. Never again will I use that shop.
    lynyrd3 likes this.
  8. Feb 11, 2020 at 2:56 PM
    IowaDucknDeer
    Curt
    2007 tacoma
    ***Update***
    Got home and looked under the truck... leaking again from the transfer case.
    I’ll be at their door first thing in the morning.
  9. Feb 12, 2020 at 11:04 AM
    IowaDucknDeer
    Curt
    2007 tacoma
    Update: And my patience is being tested further. These guys cracked my transfer case and that is the cause of the leak.
    They are getting a new one and replacing it at no cost.
    not happy with these clowns.
  10. Feb 12, 2020 at 12:11 PM
    Muddinfun
    Muddinfun Well-Known Member
    How in the F*** did they manage that? These guys are a real piece of work.
    TnShooter likes this.
  11. Feb 12, 2020 at 12:14 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Wow. What the heck?
  12. Feb 12, 2020 at 12:19 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    "reputable shop"
    ha
    Muddinfun likes this.
  13. Feb 12, 2020 at 1:23 PM
    IowaDucknDeer
    Curt
    2007 tacoma
    They tried to say that the wobbly harmonics from a loose pinion in the differential may have caused a stress fracture and that it expanded from there. I called them on it and said that it was very coincidental forward to occur only after they fixed The differential that the crack appeared. They admitted that there was no sign of a crack or leak before they took out the differential.
    Does anyone have any idea what it would take to crack the differential case?
    I say reputable shop based on the fact that he has Seemed to be honest, not take on extra work, and to honor up to their mistakes and not charge me for them. I think he’s an honest review a man but I think his mechanics suck
  14. Feb 12, 2020 at 3:53 PM
    TnShooter
    Deogee
    STOCK
    Crack the Differential Housing or Transfer Case?
    Yes, you could bust the Differential Housing if you smacked it on a something.
    This has been known to happen and even more so if you run a diff drop kit.
    As for the Transfer Case, not really?
    Not unless you were to use the Transfer Case as a lift point?
    Stranger things have happened? But I can’t think of an easy way right off hand?
  15. Feb 12, 2020 at 4:15 PM
    Muddinfun
    This thought occurred to me. Single post hoist ended up hitting the transfer case?
    TnShooter[QUOTED] likes this.
