Front disc brake click/clack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by studunk1, May 13, 2019.
  1. May 13, 2019 at 5:53 PM
    studunk1
    studunk1 [OP] Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Have 2013 access cab,6 cyl, auto trans, totally stock sr5, 4 wh drive, tow pkg, 57k miles, bot new. About 6 mos ago noticed a click/clack (think a noise similar to a torque wrench), every time truck reverses direction, and noise is getting more pronounced and predictable. Drive into the driveway forward, then when backing out applying brake pressure hear a click/clack, only one time. Start forward with no more click/clack until I apply brakes at first stop. During the slow down and brake pressure again a one time click clack. Each time vehicle reverses direction I experience the click clack only one time, then no more symptoms until direction reversed. It is as if something in the brakes, suspension, or front wheel drive assembly, resettles after a teeter-totter weight distribution effect. Pulled front wheels everything looks, feels great and tight.
    Searched forum and found no discussion on this. Any one else know of this problem?
  2. May 13, 2019 at 6:10 PM
    BuschWacker
    BuschWacker Well-Known Member
    Calgary, Alberta
    2015 TRD Sport DCLB
    I had the same problem. There is a spacer/shim on the back side of the brake pad. I took it off, added some lube, put it back together. No more click.
    Juforrest and whatstcp like this.
  3. May 13, 2019 at 6:15 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    There are many threads on this and I had the same problem. New OEM pads installed on clean brackets with well lubed hardware solved it for me. I assumed my pads were due for replacement anyway at about 50,000 miles. They had more that 1/2 the material still left. I put in the new pads since I had them.
  4. May 13, 2019 at 6:26 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    I put two springs on mine to solve this
    2WD likes this.
  5. May 13, 2019 at 7:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Or just ignore it as it isn't hurting anything and doesn't make much noise at all IMO.
    b_r_o and tacotrucktrd15 like this.
  6. May 13, 2019 at 9:27 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I had same issue and did the dual spring mod and it worked perfectly. The factory only puts one brake pad spreader spring per caliper, on the bottom. Buy 4 new springs and place on the top and bottom, and voila, problem solved. I cleaned and lubed while I was in there and put new guide pins as well.
    dawgn86, Atlas86 and whatstcp like this.
  7. May 13, 2019 at 9:30 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    whatstcp likes this.
  8. May 14, 2019 at 3:19 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Permatex has brake quiet to apply to rear side also. My powerstop z36 pads have a rubber backing. Another source of this could be slight binding as the caliper mounting bracket builds up rust/deposits in the grooves in which the brake pads mount/slid so during a pad install always chip/clean them out and ensure free pad movement. The posts above on springs/pins/grease are all things to do too.
  9. May 14, 2019 at 5:46 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    My 13 did it all the time, got used to it. Then at 90,000 miles I replaced with OEM pads, no more noise.
    I would think if you removed the pads and cleaned everything off, lube, and re-install, the noise would stop.
  10. May 14, 2019 at 5:58 AM
    GMan8402
    GMan8402 Well-Known Member
    98 SR5 4x4 / 14 Prerunner TRD OR 4x2
    My 14 does this. It will also clack when applying the brakes after a turn. I don't think it hurts anything since my brakes are still super sensitive... Almost too sensitive.
  11. May 14, 2019 at 7:01 AM
    NavyGuyAN
    NavyGuyAN Well-Known Member
    Virginia Beach, VA
    2010 Silver Taco 4x4
    Wet Okole Seat covers, Weathertech Floor mats, Blistein 5100's all-around, BFG KO2’s Fumoto Drain valve
    My 2010 does this still sometimes I asked the stealership Last time I brought it in and they said that when you back up and then go forward it’s your brake pads adjusting, is what I was told
  12. May 14, 2019 at 7:52 AM
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    Hey 2wd, where did you buy your brake hardware. Will be doing my front brakes soon and will definitely use 2 springs per per side
    Thanks
  13. May 14, 2019 at 8:24 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try the double spring mod, other than that, dont worry about it
  14. May 14, 2019 at 4:52 PM
    2WD
    Pete
    I think it was Rock Auto. Also, the picture I posted needs one more box of pins to do the pins on both sides.
    Tdkrum5 likes this.
