Front Door speaker replacement (7" non JBL system)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fatchickonadiet, Apr 12, 2016.
  1. Apr 12, 2016 at 8:57 PM
    fatchickonadiet
    fatchickonadiet [OP] Well-Known Member
    I'm looking for a direct replacement for factory speakers.
    I'm not an audiophile but like good sound. Which would you get from these for direct drop in replacement?
    Kenwood's have a ton of positive reviews, but I know Pioneers are good as well.
    Which and Why ? thanks
  2. Apr 12, 2016 at 9:02 PM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    Those all seem cheap but I've not looked into audio much yet as I'm still trying to build my suspension system. Does ur setup have a separate tweeter in the door already? If so I'd go for a single midrange without a tweeter in it
  3. Apr 12, 2016 at 9:11 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    I'm assuming that's Crutchfield's website...
    I wouldn't suggest just a simple speaker swap with any of those (though they would work fine)... I believe your stock speaker size is a 6x9" speaker, so if you're looking for a simple swap of the main woofer, I would say just get yourself a 6x9 instead.
    If you want better sound, I would highly suggest getting a set of component speakers instead, though they won't function up to top levels until you add in an amplifier. And don't forget that your system will only sound as good as your weakest link, so after replacing your speakers, that's your headunit
  4. Apr 12, 2016 at 9:32 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Wow, those speakers may actually be worse then the factory ones. My recommendation is to not even bother unless it's a clear upgrade. Your factory ones will be covered under bumper-to-bumper warranty should you blow them out, etc.
    Probably the cheapest priced speakers I'd consider are the Alpine SPR-60C. They should be a pretty simple pop-in DIY install. But has been said, next it'll be adding a new head unit and an amp(s). Some better speaker wires also a must. So, might want to grab some really good speakers right off?
    Maybe this TW thread on 3rd gen stereo/speaker upgrades will be helpful to you...
  5. Apr 12, 2016 at 9:37 PM
    fatchickonadiet
    Thanks
  6. Apr 12, 2016 at 9:40 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Don't take the interior of your brand new truck apart. Leave it alone. They never go back together again like they do from factory. You'll have rattles and broken or missing clips and damaged door panel lining down the road. Yes even when I've paid reputable shops money to do this it's never quite the same.
  7. Apr 13, 2016 at 4:52 AM
    senayski
    senayski Well-Known Member
    Pittsburgh, PA
    Polk db's (marine proof) were my go to on my jeep. crutchfield has a whole speaker kit for the 16 taco. ~$300 i think. I plan on swapping them all out in the future, and add an amp as well.
  8. Apr 13, 2016 at 5:10 AM
    ElderP
    ElderP Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
  9. Apr 13, 2016 at 9:48 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Sounds like someone didnt know what they were doing then. I have done my own audio in numerous cars with no damage, rattles, etc.
    That being said - I would go with a component system such as Alpine or Infinity if you want to keep costs down... otherwise I like Focal's.
    JohnDeere55, senayski and TurboGT like this.
  10. Feb 9, 2019 at 11:55 PM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    Anything is an upgrade to factory.
  11. Feb 10, 2019 at 2:29 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    For real, a styrofoam cup is better than OEM. :rofl:
