Front Door Speakers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kahanabob, Nov 2, 2021.
  1. Nov 2, 2021 at 10:15 AM
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i installed the kickers and they live up to their name, they kick. i know there is the sound deading material i can put in but from what i have seen it goes against the inside of the door skin, correct me if i am wrong. my issue is when playing EDM the plastic door panels vibrate to the point it sounds like a blown speaker. i put my hand anywhere on the door panel and it feels like a vibrator machine.
    any suggestions?
  2. Nov 2, 2021 at 10:22 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    So, if you have the door panel removed everything is okay? If that’s the case you will need to make sure that all of the clips are intact and if they are good I’d first try adding a thin layer of foam between the door and the panel to see if it tames the vibration.
    iblis01 likes this.
  3. Nov 2, 2021 at 10:25 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    The door panels are made up of several plastic panels that are plastic welded together. The best way to fix the rattles in the door panel is to apply sound deadener to the seams where the panels are connected together. Apply foam tape to the clips and to the door switch panel. This should get rid of most of those rattles.
