Front Doors on 2020 SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chipleyboy, Jun 7, 2020.
  1. Jun 7, 2020 at 8:58 AM
    chipleyboy
    chipleyboy [OP] New Member
    2020 Tacoma
    Have to close front doors twice to close. Is this common. What adjusted can be made?
  2. Jun 7, 2020 at 9:01 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Put the window down a little
    Skydvrr, Pinay and Black DOG Lila like this.
  3. Jun 7, 2020 at 9:10 AM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    I have to as well. I think for me it’s just a matter of breaking in the door trim, seals or whatever you call it.
    Malvolio likes this.
  4. Jun 7, 2020 at 10:07 AM
    RPVTaco
    RPVTaco Well-Known Member
    Randy
    2019 TRD PRO
    After coming from a German SUV and getting used to my wife’s Tahoe, these Tacoma doors are extremely lightweight. I still find myself having to give it a little more effort to shut completely.
  5. Jun 7, 2020 at 10:16 AM
    Criera
    Criera Well-Known Member
    South Bay SF, CA
    2020 TRD Pro
    All I can think of beyond trying harder is to Make sure all the little holes behind your rear seat are not blocked, in the back of the cab are air relief dampers (vents). If you block enough air to these you won’t be able to relieve the air pressure making the last door harder to close unless like someone else mentioned you leave a window cracked.
    zoo truck and Malvolio like this.
  6. Jun 7, 2020 at 10:22 AM
    Boyettexan
    Boyettexan Well-Known Member
    Boyette
    77584
    2021 TRD WHITE
    Ironman Nitro Stage 2,Mickey Thompson
    ill bring it back to the dealer if thats mine
  7. Jun 7, 2020 at 10:32 AM
    Criera
    South Bay SF, CA
    2020 TRD Pro
    It’s not that serious, mine just took a little getting used to when I first got it, don’t even notice it anymore, and like others mention will probably break in after a little time
    Boghog1 and Boyettexan[QUOTED] like this.
  8. Jun 7, 2020 at 10:36 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    When I first got my truck the doors were stiff, after a little while they loosened up a bit. I did also add sound deadener to the doors that gave them more mass. They close easy with a solid thud now.
    RPVTaco likes this.
  9. Jun 7, 2020 at 10:57 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Just don’t repeatedly slam your door like some person here did. It will not end well.
  10. Jun 7, 2020 at 12:30 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Every toyota i've had over the last 20 years has a pretty airtight cab needing to give the door a harder push than normal. Even after several years my passenger door on the tundra needed some extra beef to fully shut it. The new tacoma i have is the same way.
  11. Jun 7, 2020 at 12:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes.
    Try harder the first time.
    It's not the truck. It's the user.
    The other option is to have doors easy to close, but then join the thread on the 'wind whistle / Kazoo sound' crowd who get that corrected with, wait for it........ new door seals.
    Pinay and Boghog1 like this.
  12. Jun 7, 2020 at 5:42 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    My access cab doors also have a habit of not wanting to close the first time. I just make sure that the map lights are off before I leave the truck.
  13. Jun 7, 2020 at 5:48 PM
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    Interesting, I've always found my doors to be very easy to shut since new. I can literally close mine with a single finger using very little force.
  14. Jun 7, 2020 at 6:16 PM
    chipleyboy
    2020 Tacoma
    I appreciate all of the comments and see that I am not the only one. It would interesting hear more about sound deadner.
  15. Jun 7, 2020 at 7:12 PM
    Tacomike18
    J
    Someone said that if all but one of the doors are closed and you try to close the last door, the air pressure pushes out on the last door making it not close as well.
