Front drive shaft question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C4vettrn, Apr 28, 2015.
  1. Apr 28, 2015 at 2:06 PM
    C4vettrn
    C4vettrn [OP] Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    What are you guys using (Grease gun) to lube the front u-joints? I can get all but the front shaft my gun fitting wont get on it?
  2. Apr 28, 2015 at 2:25 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    You can get a 90-deg fitting or just turn the shaft. My grease gun has a short hose with straight fitting and I could get to those fittings just fine. A little tight space, but not impossible. Just have to hit them at the right angle.
  3. Apr 28, 2015 at 3:43 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  4. Apr 30, 2015 at 1:04 PM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    I will try the smaller size, thanks!
