Front Driveale, CV boot leaks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lawman, Nov 21, 2010.
  1. Nov 21, 2010 at 2:49 PM
    Lawman
    Lawman [OP] Active Member
    Jacksonville, FL
    01 Tacoma SR5 TRD
    3.5 RevTec Suspension Lift, Gray wire Mod, Snobord552's light bar, HID conversion kit, 3 SRS Off-Road lights, Dogmod
    I have a 2001 with leak in he front driveaxle, CV Boots. Does anyone have and good suggestions on fixing this?
    Complete replacement?
    Tear down and rebuild?
    Write a check to get someone else deal with it?
    I am open to ideas and also where to purchase the parts, etc. Im located in Jacksonville, FL if you are local and know a good shop.
  2. Nov 21, 2010 at 2:50 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    just the rubber boot?
  3. Nov 21, 2010 at 2:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It will be easiest to replace the whole thing but you can just replace the boots, that requires a lot more work though.
  4. Nov 21, 2010 at 3:04 PM
    Lawman
    Jacksonville, FL
    01 Tacoma SR5 TRD
    Yea its just the rubber boot. I've been looking around and it seem like a bunch of work to break it down and repair, but I have not done it, so im open
  5. Nov 21, 2010 at 3:16 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You need a tool to put on the lock ring. Clean and inspect before regreasing. You should be able to replace the boot without pulling out the shaft from the trans.
    If everything inside looks good, ie, old grease not full of grit, water and other junk, no signs of overheating, cracks, chips, etc. It's worth it to just replace the boot. Just make sure you have quick access to a new shaft if you need it, and some diff lube and a new shaft seal.
  6. Nov 22, 2010 at 7:29 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    We used to take our Honda over to the local House of Mufflers and brakes and they would replace the outer boot for $65 +tax it wasn't worth messing with for that!
  7. Nov 22, 2010 at 9:31 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Just replace the whole axle. It is way easier. When I did mine I followed this write-up and it made the process go a lot quicker. click here
  8. Nov 22, 2010 at 10:27 AM
    BeerHat
    BeerHat Got Beer?
    TX
    2001 PreRunner 4x4
    PreRunner 4x4, Homebrew Front Bumper, Homebrew Sliders, Homebrew Skids, Homebrew Bedbar, Homebrew Beer
    I just had this happen with mine. I got a set of o'reilly masterpro full axle assemblies; both for around $150 shipped to the door. It took 30 minutes to swap them out. Get a cv boot kit from trdparts4u.com or some place similar and repair the boots while the oem cv's are on the bench; much easier. It is also nice because you have 2 spares now.
  9. Nov 22, 2010 at 11:00 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If some grease is just squeezing out the end of the boot. Then just wipe off the excess and don't worry about it. If the boot actually has a tear or hole in it, then you may want to consider replacing them sometime in the near future.
  10. Dec 23, 2010 at 8:35 PM
    GOLFMAN845
    GOLFMAN845 Well-Known Member
    Nic
    2002 Black Double Cab 4x4 TRD
    Leather Interior, Hunter Bull Bar with 4" KC Driving Lights, Black Pro Comp 16" Alloy Wheels, Yokohama ATS Tires, OME 881 Coils with Bilstein 5100's set at 1", Rear Dakar Leaf Springs with Bilstein 5125's, Removed Rear Decals on Bed
    What do you think of about this?
    Passenger Side CV
    Passenger Inner /Upper Boot (even more Grease coming out now)
    Drivers Side CV
    Inner /Upper Boot
  11. Dec 23, 2010 at 8:54 PM
    CdnSldr
    CdnSldr Well-Known Member
    Josh
    Northwestern Ontario (the only good part of ON)
    '96 Sex on Wheels ;)
    Deckplate mod, Bilstein 3" C/O's, NWO 2.5" rear leafs w/ overload, OME greasable Shackles, 33/12.5/15 Dura trac's, 15" Wheelers Steelies Type "B", Sat. Radio, Diff breather mod
    That doesnt look bad at all. Just a little extra grease that is being pushed out. If you are really anal I guess you could replace the clamps, but that does require a special tool to crimp the new clamps. Other than that just clean off the grease, make sure there are no actual tears and forget about it :)
  12. Dec 24, 2010 at 11:09 AM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    If and when you do ever replace, I suggest this route, too. You can also get some at Autozone. I got mine for $150 each, but they have lifetime warranties and you get $100 back for bringing in your old ones. So in the end, each CV half axle costs a one time fee of $50 to replace, and it doesn't take long. If its your first time tearing it all apart, it'll probably take you a while, and the cone washers may be a pain.
  13. Dec 24, 2010 at 12:46 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    If grease can get out, water can get in. Grease is not a sealant. Time for an inspection and new boot, if the axle is still good.
  14. Dec 26, 2010 at 12:35 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    I just looked at my truck and its got greese everywhere from the cv, its not torn but the bottom by where the clamp is, is where the greese is coming from. Im all for letting it leak for now but what happens when there is no more greese to leak?
  15. Dec 26, 2010 at 12:51 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    One of two things: overheat and failure, or wear out and failure. It depends on what contamination is getting in.
  16. Dec 26, 2010 at 4:20 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    Well I just realized it today and I have been on some hunting trips in some pretty nasty places so im sure there's all sorts of contamination. Im just gonna replace the whole cv axle, Is there any axle that you guys recommend?
  17. Dec 26, 2010 at 4:29 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Phil,Phil,Phil.....:eek::eek::eek:
    What you think is gonna happen when the grease is gone & all thats left for lube is dirt & mud ?? C'mon buddy I know I learnt you better than that :D:D
    Hey Phil get some axles bro'.. they're actually not that expensive I did both sides for less than $200
  18. Dec 26, 2010 at 5:39 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    Hahaha I know doug, I wasn't thinking! I'm going to just do it myself. What axle brand do you guys recommend?
  19. Dec 26, 2010 at 7:19 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
  20. Dec 26, 2010 at 7:31 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I'd go OEM if you can afford it but some decent rebuilt ones are ok too
    & you'll save a few $$$
