Front Driver side axle play where it goes into the Diff.
Discussion in 'Technical Chat' started by Yoytoda, Apr 17, 2010.
  1. Apr 17, 2010 at 7:28 PM
    Yoytoda
    Yoytoda [OP] The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I noticed a strange pulsating noise in the front left of my 4x4 reg cab 2010 with 9k on the odo. Thought stock tires were giving up from offroading and the sidewall on the left tire was bruised (damaged). I rotated tires and the noise is the same. wheel bearings felt tight. brakes are fine. The only thing i notice is the axle on the left has 1/8" play in either direction ( front to rear ) I know its pretty normal for them to slide in and out but back and forth the amount seems a lot. Does anyone else have that amount of play? its only on the left side, not right. Right side is tight. Next stop, Dealer, but just trying to see if anyone else noticed much play...
    Thanks
  2. Apr 17, 2010 at 7:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i think most people (including myself) have noted more play in the drivers side...
  3. Apr 17, 2010 at 7:40 PM
    Yoytoda
    Roland
    completely stock
    ok... just trying to figure where the noise is coming from...
  4. Apr 18, 2010 at 6:06 PM
    Yoytoda
    Roland
    completely stock
    turns out its a wheel bearing on its way out with only 9k on the odo WTF!!!! thought i wouldnt have to worry about this shit since i got rid of my chevy. GHEY!!!!
  5. Apr 18, 2010 at 10:35 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  6. Apr 18, 2010 at 11:21 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    ^^private vid
  7. Apr 18, 2010 at 11:21 PM
    Yoytoda
    Roland
    completely stock
    ok cool. I went to the dealer today and all the new trucks did it too. and an FJ so now i know its normal. Bad wheel bearing after 9k not so normal.
    BTW video didnt work...
  8. Apr 19, 2010 at 2:38 AM
    DDD
    Derek
    Santa Clarita, CA
    Video Fixed now?
  9. Apr 19, 2010 at 10:52 AM
    btkicker
    Denver
  10. Apr 20, 2010 at 5:37 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    Sucks about the wheel bearing, hope the dealer will take care of it. That play in the video is pretty standard as you saw on even brand new truck. When I first noticed mine being sloppy I did the same thing at the dealer and they all did it. So have the dozens of others I have checked since. Good Luck.
