front driver side is sagging
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaV6, Mar 28, 2012.
  1. Mar 28, 2012 at 9:52 PM
    TacomaV6
    TacomaV6 [OP] Well-Known Member
    Bay Area
    1997 Tacoma 2WD v6
    Brush Guard Hid lighting Custom Prelude Fogs
    like the title says. my truck when on flat even ground the front driver side sag down a little. I had a accident before where my truck hydroplane across a divider when I was making a turn ( curve road) and since it is the driver side that hit the divider first so I presume this is why it is sagging now. however I am not sure what to check for to see why it is sagging. does anyone have any opinion and insights?
    I search nothing seem remotely related.
    :confused:
    I drive fine, just annoying how front side of the truck look much lower compare to the passenger+ rear.
    :spy: want to get it fix asap before I install my new wheels :D
  2. Mar 28, 2012 at 9:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Taco lean??:confused:
  3. Mar 28, 2012 at 9:59 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Are you lifted? I don't think i've ever seen a stock truck with a taco lean.
  4. Mar 28, 2012 at 10:39 PM
    TacomaV6
    Bay Area
    1997 Tacoma 2WD v6
    not lifted stock :O I drive a 2wd :\ how I envy 4x4
  5. Mar 28, 2012 at 10:39 PM
    TacomaV6
    Bay Area
    1997 Tacoma 2WD v6
    :[ but its only on 1 side
  6. Mar 28, 2012 at 10:40 PM
    TacomaV6
    Bay Area
    1997 Tacoma 2WD v6
    I will try to post picture tomorrow
  7. Mar 29, 2012 at 12:15 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Driver Side lean=taco lean
    It's from the weight of the driver, fuel tank, and battery. Normal for stock it lifted....especially on tired old suspension
  8. Mar 29, 2012 at 3:22 AM
    TacomaV6
    Bay Area
    1997 Tacoma 2WD v6
    :eek: really.
    but I will take a picture just in case.
    cause its leaning quite quite low.
  9. Mar 29, 2012 at 3:23 AM
    TacomaV6
    Bay Area
    1997 Tacoma 2WD v6
    oh I forgot to mention. anyway to make the driver side evenly? I dont like how both rear + passenger side look normal but my driver side look a bit funny
  10. Mar 29, 2012 at 6:52 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    You get the lean from being stock too.
  11. Mar 29, 2012 at 11:06 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    Not calling you a liar, just saying i've never seen a stock taco lean. I didn't get a lean until after I lifted. I still have a bit of lean even with the lean spacer.
    Gonna start keeping an eye on stock Tacos, see if I notice any leans.
  12. Mar 29, 2012 at 11:13 AM
    scocar
    scocar hypotenoper
    Really. Worn out coil spring probably making it worse.
    Take a picture of the top of the coil spring for us. It's is a progressive spring, and the coils at the top are softer, but if they are squashed down and almost touching each other, they are likely toast. Replacing the coils would get you back to stock ride height (assumingno other factors or damage). How many miles?
  13. Mar 29, 2012 at 1:41 PM
    TacoMX
    Jonathan
    Deltona, Florida
    worn leafs can contibute to it too....but OP said his was only leaning in drivers front.
    My taco lean is pretty bad front and back. My driver side leafs are significantly more negatively arched than the passenger side.
    Coilovers and wheelers 5 pack will fix that soon :thumbsup:
  14. Mar 29, 2012 at 2:08 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    This.
  15. Mar 29, 2012 at 4:37 PM
    Dbmann80
    Dbmann80 Well-Known Member
    Michael
    Agoura hills, CA / Grants Pass, OR
    04 LT 4x4 DMZ,CAMBURG ,13 cummins,13gtr,15gtpp
    Front camburg longtravel w/fox shox, tundra front cv's/axles, custom front bumper made by camburg w/hella 4000s,rear bed cage with 16 inch triple bypass fox shox,under sprung f67 deaver , fox bumps all corners, glassworks all corners, kar-tek limit straps all corners,DMZ fabrications, meathod race wheels, general red labels, Too much to list, and more to come.
    Is your taco 1st gen? if so that's normal, all first gens lean a little on the front driver side.
  16. Mar 29, 2012 at 4:38 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    mines a 2nd gen and I have the taco lean..driver side is about an inch lower than passenger. it annoys the hell outa me
  17. Apr 2, 2012 at 2:51 PM
    TacomaV6
    Bay Area
    1997 Tacoma 2WD v6
    sorry for the late reply (had an accident), but here is the best picture I can get.
    is it normal? it doesnt bother me as much just like a flat evenly truck.
  18. Apr 2, 2012 at 2:56 PM
    TacoMX
    Jonathan
    Deltona, Florida
    yeah, its super hard to tell with that pic.
    A pic from ground level would be best.
    But, from that picture it seems like its not too obvious.
    Like I and others have said...taco lean on the drivers side is normal.
    New suspension (coils, struts, leafs) will fix it.
  19. Apr 2, 2012 at 2:56 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    you'll need to take a better picture so we can have something in the picture for comparison. But yeah, the lean is pretty normal. New coils will probably straighten you up.
  20. Apr 13, 2012 at 6:22 AM
    tybikes
    tybikes Member
    I've had the same issue in my 2010 double cab on stock suspension. I just measured and the front driver side is about 3/4" lower than the front passenger. I only have 33k miles, can the coils really be worn out this quickly? I don't offroad really, but do drive in and around NYC on really rough roads.
    Any suggestions that won't break the bank would be appreciated.
