Front Drivers Door Sounds Hollow When Closing (DC)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by floridaoccifer, May 25, 2010.
  1. May 25, 2010 at 2:49 PM
    floridaoccifer
    floridaoccifer [OP] Civil Servant
    I am not sure if anyone has had this issue or not but when I shut my drivers side door it sounds like there is something inside (metal) slapping together. I have already pulled the door panel apart and attempted to locate anything loose but nothing obvious popped out at me. All of the other doors on the truck shut solid and without any noise...
    Help? :confused:
  2. Jun 21, 2010 at 10:12 AM
    floridaoccifer
    Well I opened my drivers side door and found the metal crossbeam inside to be the problem. It appears that there are some sort of bumpers or sound absorption material on the inner door. The one closest to the hinge was not working and allowing the crossbeam to vibrate each time the door was closed. I added a little weather stripping material under the beam and the noise finally went away...
    Toyota wanted to charge me $92.75/hr to diagnosis the noise... :eek:
  3. Jun 21, 2010 at 10:55 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    :eek: I am in the wrong line of work!
  4. Jun 22, 2010 at 6:10 AM
    el_smurfo
    el_smurfo Well-Known Member
    So is he...the wife's Mini repair guy charges $120.
  5. Jul 25, 2016 at 9:07 AM
    Tmillz951
    Tmillz951 New Member
    99 Black TRD Tacoma, 85 Orange Toyota Pickup
    My 99 Tacoma just started making this awful noise, everytime i close door with window up or down. So does the cross beam just lose its padding or what?
  6. Jul 25, 2016 at 2:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do you expect them to work for free or are you still under warranty?
