Front Driveshaft issue after greasing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Mar 1, 2013.
  1. Mar 1, 2013 at 1:24 PM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just greased the driveline zerks. When doing the rear zerk on the front shaft (the one you need to remove the small skid plate for) i noticed when greasing one of the plastic rings was broken and just barely hanging on. The rings are located on each side of the spider bearing (i think that's what it's called) where the old grease comes out when pumping new grease in. Are these plastic rings a seal or dust cover and is it anything to be real concerned with when one is missing? Thanks...
  2. Mar 1, 2013 at 2:27 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    It's probably a seal of some type. If you see alot of grease coming out of that area it could be a problem depending on much you use 4wd. I don't think it needs to replaced right now but it's something to keep an eye on
  3. Mar 1, 2013 at 2:31 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  4. Mar 1, 2013 at 2:43 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If its on the inside... like in this photo
    It's a seal (per say). If that is missing...you'll need to grease the joint more frequently, or the needle bearings will dry up. Water/dirt will get inside and ruin the bearing if you don't keep it lubricated.
    Or...put a new one in....and don't worry about it.
  5. Mar 1, 2013 at 4:20 PM
    OffroadToy
    here ya go... picture of it on and what it looks like missing.
  6. Mar 1, 2013 at 4:27 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Looks like its time for a new universal joint. They're cheap and easy to change.
  7. Mar 1, 2013 at 4:28 PM
    OffroadToy
    Thanks Janster... i think that's them. Do you know if the dealership sells just the seals or do you have to purchase the whole unit?
  8. Mar 1, 2013 at 6:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    To replace the seal you have to remove the U-Joint. It would be smarter to just install new U-Joint(s).
  9. Mar 1, 2013 at 8:09 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Just remember when you get a new on in to grease it slowly. You can pop or break seals by pumping the grease to fast or hard.
    You could be fine with that for a while? But i'd put a pump in once a month. Or after a rain storm.
    But yeah you have to do the whole thing they don't just sell the seals.
  10. Mar 2, 2013 at 4:46 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yeah you need new unjointed. It's not emergency but sooner rather than later. Keep current greased.
  11. Mar 2, 2013 at 6:13 AM
    Janster
    Jandy
    Lancaster, PA
    Like everyone has said...You'll need a new u-joint. They don't make or sell seals to replace 'em.
    If you can't do it right away - that's fine. Make sure you keep it lubricated regularly until you can get it replaced.
    A new U-joint is cheap.... the labor will be more expensive. You can do it yourself with some research.
