Front emblem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma mud, Sep 13, 2011.
  1. Sep 13, 2011 at 7:30 PM
    Tacoma mud
    Tacoma mud [OP] Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    Yea i was looking for the dimensions of the front toyota emblem.
    What hold it on? And will i have to take the whole front grille off to get to it?
  2. Sep 13, 2011 at 7:34 PM
    soupman77
    soupman77 Well-Known Member
    Alan
    Texas
    08' 4DR Tacoma LB 4x4 TRD Sport
    Revtek 3" Leveling kit with 1.25" in rear. Grillecraft mesh grill with TRD emblem, Hella 500's mounted behind grille, horn relocation, blacked out lower valence, allpro offroad bumper, blacked out roof, and so much more to do...
    There are three small tabs that hold it in place. To remove it, apply pressure evenly to them and it'll pop off. You may need to remove the front end, but not sure. I pulled mine off and went with a Grillecraft.
  3. Sep 13, 2011 at 7:34 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    2 screws.
    and you can do it without taking grill off..if you have tiny tiny hands to go between the girll and core support.
    Taking grill off is easy.
    1. Take a t-stat or skinny skinny screwdriver(like for adjusting sprinkler heads)
    2. Kneel down and look up to your grill clips where they are held on with the grill mounting points..you'll see a little tab..use the screw driver to push up that tab while pulling on that section of grill.
    3. Repeat for all grill mounting points.
    4. Carefully pull grill off..most clips will stay in core support but some might fall out..so watch them to make sure you don't lose them. The clips are $1.50 each from the stealership.
  4. Sep 13, 2011 at 7:57 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    I was gonna try to make the badge with the devil horns, i think itll look pretty nice :thumbsup:
