Front End "bucking" hard when 4x4 is engaged
Discussion in '1st Gen. Tacomas (1995-2004)' started by DFM5, Dec 8, 2013.
  1. Dec 8, 2013 at 9:50 AM
    DFM5
    DFM5 [OP] Active Member
    Daniel
    Colorado
    02 TRD 6" Fabtech lift
    6" Fabtech lift
    Had a pretty bad snow storm last week in CO. Threw the truck in 4hi and the front end started "bucking" really hard! (Bounced my coffee out of the cup holder and all over the passenger seat) 4x4 engages and disengages just fine but it feels like the gears are just bouncing instead of seating together. Does anybody have any input as to what the problems could be? Tcase? Hubs? Front Diff? I can't imagine it would be the front diff because the front diff is still in use even when the truck is in 2hi and there are no problems. The front drive shaft seems to be all good as well. My clutch has been acting a little finicky lately as well.. Pretty sure it is going out, but could that possibly be the issue?
    Anything helps.
    Thanks
    D
  2. Dec 8, 2013 at 9:56 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Clutch slippage could definitely cause bucking. Any difference in size between front/rear tires? Truck ever been regeared?
  3. Dec 8, 2013 at 9:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Change the diff fluid and see if there are any metal chunks. I would also wonder if the rear had been regeared and not the front. How long have you had the truck and have you ever had it in 4wd before?
  4. Dec 9, 2013 at 11:28 AM
    DFM5
    Daniel
    Colorado
    6" Fabtech lift
    Tires are the same size on front and back.. I did put in a new rear diff about 2 months ago. Never had an issue with 4wheel prior to that change. Had a guy I know who works at the dealership do it for me. I would assume he geared it correctly..
  5. Dec 9, 2013 at 11:29 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Were you turning when this bucking occured ?
  6. Dec 9, 2013 at 11:33 AM
    DFM5
    Daniel
    Colorado
    6" Fabtech lift
    I have had the truck for close to 3 years.. Lived in Colorado the whole time so I use 4x4 pretty regularly during the winter. Plus do a good bit of off roading stuff. I put in a new rear diff a couple months ago. Could that be geared differently causing the bucking?
  7. Dec 9, 2013 at 11:34 AM
    DFM5
    Daniel
    Colorado
    6" Fabtech lift
    Its pretty much all the time. If i get it over 5 mph in 4wd it starts bouncing hard
  8. Dec 9, 2013 at 11:37 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    I would be looking at the new gears as primary suspect as this started after the swap, triple check gear ratios, even if it means pulling the new third member to check, I think they have some kind of tab with a number or gear info you can check, hopefully saving a yank...
  9. Dec 9, 2013 at 11:55 AM
    DFM5
    Daniel
    Colorado
    6" Fabtech lift
    Where would I find that info? That is why I had the dealership do it b/c I have very little knowledge with diffs and gearing ratios and what not.
  10. Dec 9, 2013 at 12:05 PM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Check your bolts for the front diff drop bracket. I had the same thing happen on my old truck could not figure it out till the bolt disappeared and took out the CV and shock with it.
  11. Dec 9, 2013 at 12:25 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Should be able to jack up the rear and count the rotations of the drive shaft per wheel rotation. 4 1/2 rotations is roughly 4.56 gearing, a little over 4 spins is 4.10. That's the simple way to check. Should work for the front as well.
  12. Dec 9, 2013 at 2:51 PM
    DFM5
    Daniel
    Colorado
    6" Fabtech lift
    Went digging through the glove box and found old paper work for when the previous owner had the 6" fabtec lift put in.. He had it regeared to 4.56. When I had the dealership put in the new rear diff. the instaled a 4.10 which is the stock gearing. So thanks for the tips guys. Now I get to go fight with the dealership to fix it!
  13. Dec 9, 2013 at 3:21 PM
    whahahajr
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Dang that sucks.
  14. Dec 9, 2013 at 3:38 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You might lose that fight. They assumed stock gears and had no reason to assume anything else. Hopefully, if they take pity on you, they might just charge for labor to install proper diff, to keep your business.
    On second thought, the tech should have noticed the 6" lift, and asked you if it had been re-geared. Were the tires bigger than stock?
  15. Dec 9, 2013 at 4:35 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    The only way to find out is go in with a smile and start a discussion, maybe have the gearing information at the top of glove box so when opened it is the first thing you see...if you had bigger tires and a lift, that should have set alarms bells off for gearing, first thing is they should have verified what was in there to begin with, and, just to make it more their fault, all they had to do was examine the one that came out FIRST, very simple, it would have been obvious before anything went back in...
    good luck, I hope you win this one...
  16. Dec 9, 2013 at 7:12 PM
    whahahajr
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Clearly they never test drove it either.
