Front end click/clank metal sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingtaco, Apr 19, 2014.
  1. Apr 19, 2014 at 6:03 PM
    kingtaco
    kingtaco [OP] Well-Known Member
    San Gabriel Valley
    Does anyone here hear a metal click or a clank type sound when hitting a bump or turning. I have a '06 with 3" spindles and bilstien set at the 2nd notch. Had this set up for 3 years. The noise started 6 months ago.
    It's not a loud noise. It's like lightly tapping a small hammer on metal. I've checked the front end more times than I can remember in the last few months. The truck tracks straight, no wabble, the suspension feels solid.
    Any ideas would be greatly appreciated.
  2. Apr 19, 2014 at 6:08 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Sway bar links if your still running it.
  3. Apr 19, 2014 at 6:32 PM
    kingtaco
    San Gabriel Valley
    Yeah I am. Are they worn out or loose?
  4. Apr 19, 2014 at 6:32 PM
    kingtaco
    San Gabriel Valley
    Yeah I am. Are they worn out or loose? Thanks for the reply.
  5. Apr 19, 2014 at 6:33 PM
    Redneck92
    Concord, NC
    Could be either but more than likely worn out depending on mileage. Just undo them and check for play in the joints.
  6. Apr 19, 2014 at 6:39 PM
    kingtaco
    San Gabriel Valley
    Yeah I'll check them after the fights. I checked every thing but that. Thanks
  7. Jun 30, 2014 at 2:33 PM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    I was just going to make a new post but this sounds like what I got going on. It clanks when I hit a dip in the road but if I hit multiple bumps it stops. OP was that it?
  8. Oct 12, 2014 at 8:52 PM
    HB Taco
    Curt
    This weekend I removed the sway bar. I still get the clank noise when I hit a dip or big bump. everything seems tight in the susp. Grabbed the tires while lifted and no play whatsoever. WTH? Any suggestions?
  9. May 26, 2017 at 11:40 AM
    ARCOVT16
    ARCOVT16 Well-Known Member
    VT
    2016 DCLB SR5
    Icon ext Travel Coilovers, SPC UCA, SCS 16x8 Wheels, 285/75r16 G003, Toytec 3leaf AAL, Icon 2.0 Remote Reservior, Toytec Axle shims, Toytec Front Diff drop, Timbren U-Bolt flip kit, Clazzio Black Seat covers.
    Bump
    any further info on this?
  10. May 26, 2017 at 1:28 PM
    camdenthekid
    camdenthekid Well-Known Member
    Camden
    Sacramento, CA
    08 Silver ORAC
    5100s, 886, super bumps, Deaver progressive AAL, u bolt flip and timbren bumps. 295 70 17 Falken MTs.
    I have it on the driver side more than anything with mine under some turning. Passenger side has a little knock under full down travel unweight type stuff. I'm guessing its my shock set up at this point (toytec 3in spacers up front)? Not running a sway bar. Tie rods just replaced and ball joints / axle boots are all good. I'm in the same boat where there is no play just a random knock every now and a again.
  11. May 26, 2017 at 2:58 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Worn brake pads in the caliber . I get a clicking noise after backing out of the driveway and the 1st time I apply the brakes going forward 42k miles
    TOMB
