Front End Clicking sound.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiatt1991, Jan 29, 2012.
  1. Jan 29, 2012 at 10:43 AM
    Hiatt1991
    Hiatt1991 [OP] Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Hi guys. I have recently noticed that when I coast, I get a weird clicking sound that seems to be from the front end. It starts when I am either coasting really slowly to a stop, or when I apply the breaks. From the info I have read on here, it seems like it could possibly be the wheel bearing. I jacked up the truck and shook both front tires but the dont seem to have any play but when I spin the tires, I can hear a really slight noise that resembles the clicking, but im not sure if Im being overly particular. I dont have any kind of locking hubs either. Just bilstein 5100s, camburg ucas, KMC enduros and 285s. Any help would be greatly appriciated.
  2. Jan 29, 2012 at 10:46 AM
    IKMtacoma
    IKMtacoma Well-Known Member
    sounds like the shaft issue - there is a thread about it somewhere on here.
  3. Jan 29, 2012 at 10:48 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Drive shaft? Could be possibly. I havent gotten the carrier bearing drop from beefed tacos yet from the lift but it never made a clicking noise. Just an occasional groan sometimes. Its just it sounds like it comming more from the front.
  4. Jan 29, 2012 at 10:51 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    It could be the fit kit in the brake calipers shifting. They might need a clean and lube.
  5. Jan 29, 2012 at 10:52 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    What is the fit kit?
  6. Jan 29, 2012 at 10:53 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    BTW it seems like it got a little bit louder today. Either that or Im being picky. lol
  7. Jan 29, 2012 at 10:54 AM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    It is the little pins that the brake pads sit on. There is also a little bracket that looks like a "Shepards cane" I suppose. What year is your truck?
    NM its a 2005. It sounds like its coming from the front? You could also get a grease gun and hit the slip yokes/u- joints on the front and rear drive shafts too. Unless you JUST hear it when you hit the brakes.
  8. Jan 29, 2012 at 10:57 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Well I hear it when Im comming to a stop (coasting) but it is definatley more prominate when I hit the brakes. Ill try out the grease gun.
  9. Jan 29, 2012 at 11:03 AM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    If it happens when you brake, it is more likley the pads shifting in the caliper. However, the grease gun is a good idea anyways.
    See the pic taken from badguybusters how to.- Its the pin going across the pads- I would use a brake caliper lube on them.
  10. Jan 29, 2012 at 11:08 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Oh ok I see. Ya I changed the breaks myself and I was very liberal with the anti friction past that I put on the back of the pads. It could very well be that clip because the clicking sounds slightly metallic as if it were a clip.
  11. Jan 29, 2012 at 11:09 AM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Its also important to apply the lube to the pin itself, so when the pads shift it doesn't make noise.
  12. Jan 29, 2012 at 11:11 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Ok. Ill try that.
    Just to describe the sound better, it sounds sort of metallic and it happens every time the wheel makes a full rotation.
  13. Jan 29, 2012 at 11:13 AM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    That could be a "high"spot and glazing on the rotor.
  14. Jan 29, 2012 at 11:26 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    High spots won't cause a clicking noise...you'll feel a shimy in the steering wheel when on the brakes
  15. Jan 29, 2012 at 11:45 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Ya. I'm almost certain its those wheel bearings.
  16. Jan 29, 2012 at 11:51 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    I have a similar clicking when I put the breaks on at low speeds, and coasting. I'm dead certain it's coming from the front left wheel, inclined to think it's the pin aforementioned. I'm interested to see where this goes. Sub'd
  17. Jan 29, 2012 at 12:35 PM
    Hiatt1991
    Hiatt
    Ventura, CA
    Glad I'm not the only one but sorry its happening to you too. If its not the clip, I'm definitely going to change out the wheel bearings.
  18. Jan 29, 2012 at 2:06 PM
    Darth_Yota
    Cam-moron
    Somewhere USA
    I'll be sure to let you know how things turn out with my click. This upcoming weekend I might jack her up and have a look see. Hopefully it's not a bearing....
  19. Jan 29, 2012 at 2:09 PM
    Hiatt1991
    Hiatt
    Ventura, CA
    Bearings aren't that hard to replace if you get the ones that bolt on instead of being pressed in. I kind of hope it is my bearings because everyone I've talked to that has gotten their bearings changed said it drove so much better/smoother and their steering felt better.
  20. Jan 29, 2012 at 2:13 PM
    Darth_Yota
    Cam-moron
    Somewhere USA
    Well I would assume a bearing is covered under warranty? If isn't the clip I'll have Toyota take a gander.
