Front End Clump sound After FOX install
Discussion in 'Suspension' started by pngo121, Nov 5, 2015.
  1. Nov 5, 2015 at 11:26 AM
    pngo121
    pngo121 [OP] Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    Hi, after my lift install I'm getting a clumping noise when i hit speed bumps and dips. I've gone through and made sure all the torque was done corretly and it's still making the noise. There isn't any evidence of rub or anything. My LCA bolts are all torqued to spec as well. Any ideas on what it may be?
  2. Nov 21, 2015 at 7:41 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    It's pretty common to get new noises after you swap suspension parts. If you've checked everything and it's all how it's supposed to be than you're good.
  3. Nov 21, 2015 at 7:57 PM
    pngo121
    Phi
    Pittsburg, CA
    I figured out what it was. They sent it to me with the spacer on driver side backwards. Had the longer spacer on back.
  4. Nov 22, 2015 at 10:16 AM
    Jpgmotoman
    Jpgmotoman Well-Known Member
    Upper ball joint on uca
