Front end clunk clunk noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hauser94, Jun 19, 2024.
  1. Jun 19, 2024 at 6:50 PM
    Hauser94
    Hauser94 [OP] Well-Known Member
    2016 Black Tacoma SR5 DCSB
    Hey ya’ll need help diagnosing;
    I’m hearing a front end clunk clunk noise when going over bumps or jerking the wheel right to left or left to right. Any ideas. I got under her and checked make sure nothing is loose the pins on the brake pads I noticed slide back and forth. Is that normal? Someone on another thread said the caliper pads?
  2. Jun 19, 2024 at 7:17 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Any mods to the truck?
  3. Jun 19, 2024 at 7:22 PM
    Hauser94
    Trd skid plate
    Trd pro 4runner wheels 255/75/17 michelin defenders
    Everything else 100% stock
  4. Jun 19, 2024 at 7:55 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Pads will do that but generally only once after changing directions (forward, reverse, park). I've heard that the connection to the lower control arms can make this noise as well, but don't quote me on that.
    Have you lifted it into the air to see if there's any play in the front tires? Could be ball joints, tie rods, or even wheel bearings. Given that it happens over bumps I'd venture to guess ball joints IF it is either of those.
  5. Jun 19, 2024 at 8:01 PM
    Veet-88
    I would lean towards swaybar end links or bushings. Worst case LCA ball joint
    wilcam47 and bkhlrTaco's like this.
  6. Jun 19, 2024 at 8:08 PM
    lupercal
    lupercal Well-Known Member
    Portland, OR
    2020 OR DCSB
    Definitely check the sway bar / end links.
    bkhlrTaco's likes this.
  7. Jun 20, 2024 at 3:54 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Did I miss the mileage?
  8. Jun 20, 2024 at 4:03 AM
    Clymber
    Clymber Well-Known Member
    Vermont
    Trd
    Check upper and lower control arms. Jack truck up and see if there is any play in the wheel. Grab top or bottom and pull and push. It shouldn't move at all
  9. Jun 20, 2024 at 5:08 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    The clunk I hear has gotten so loud I had the dealer look at my front end just to make sure I wasn’t missing anything. It got noticeably louder after 17k miles, but they confirmed that while it is loud , it is ‘normal’ and recommended I regrease the pins . Have had 4 Tacomas but never heard it get to this volume before . Now that I know what it is, it’s a lot less annoying .
  10. Jun 20, 2024 at 8:48 AM
    Hauser94
    Regrease the pins? What pins and what kind of grease?
  11. Jun 20, 2024 at 8:49 AM
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    I had this, but only after I had my leaky power steering rack replaced. There was air in the lines.
  12. Jun 20, 2024 at 8:55 AM
    Hauser94
    43000
  13. Jun 20, 2024 at 8:56 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    It isn't hard to remove the swaybar to rule out links (like mentioned above)
    or bad swaybar bushings.
  14. Jun 20, 2024 at 10:13 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
  15. Jun 20, 2024 at 10:41 AM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Radiator bushings might be shot
  16. Jun 20, 2024 at 11:18 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I had a bad sound from my DS front end.. found out to be a bad swaybar link it seemed tight when the suspension was loaded.. but once I jacked up one side and placed it on jackstands.. and used the jack under the knuckle...... replaced.. and it disappeared... however it has returned... need to find some greasable links that last.... I ran without a swaybar for about 9 months.. it was scary on the highway when making a panic steer so I put it back on...
  17. Jun 21, 2024 at 8:06 AM
    Hauser94
    Update; had to different mechanics look at it and they still can’t figure out the problem. I’m at my wits end. They said everything in the suspension sway bar all that is all tight and good conditions. Should I just change the brakes and hope for the best?
  18. Jun 21, 2024 at 8:59 AM
    joba27n
    Nolan
    Alberta
    To rule out the brakes, try to recreate the noise with a helper standing in the brakes. If the noise goes away then it's not your brakes. Put your hand on things while the noise occurs, sometimes feeling is better than hearing
    Hauser94[QUOTED][OP] likes this.
  19. Jun 21, 2024 at 10:53 AM
    Veet-88
    Next one is check your skid plate. I have heard of it causing issues but not very often
  20. Jun 21, 2024 at 11:10 AM
    Hauser94
    I think I’m going to replace the brake pads tomorrow see if that fixes the problem
    joba27n[QUOTED] likes this.
