Front end clunk/knock over bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ortacoma10, May 9, 2025.
  1. May 9, 2025 at 2:44 PM
    Ortacoma10
    Ortacoma10 [OP] Well-Known Member
    2010 Tacoma Trd Off-road 4x4
    Hey guys, I was able to record this clunk/knock sound I’ve been trying to find for months on the front end suspension
    new parts recently:
    Steering rack with inner and outer TR
    Front struts
    Swaybar bushings
    I’m wondering if it’s a ball joint on upper or lower control arms? This is recorded on the passenger side. I did driver side too but the sound is louder on passenger side. Any help is appreciated I’m no expert, but I try to do most work myself on this truck as much as possible. TIAhttps://youtube.com/shorts/a_m7Nqrpyik?si=qev_TNhSrK7-Iqhg
  2. May 10, 2025 at 7:13 AM
    Toyrookie
    Toyrookie New Member
    2007 white Tacoma
    I had a s-10 that a bodyshop looked and looked for my noise and gave up tightening many bolts at no charge .
    I dis a break job not long after and found the clip that holds the shoe in was broken . It was the culpret
  3. May 11, 2025 at 8:42 PM
    clebner
    clebner New Member
    2009 Tacoma TRD sport DCLB
    Have a similar issue, I believe it to be the skid plate.
  4. May 12, 2025 at 10:40 AM
    TXTaco211
    TXTaco211 Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
    If this just started and you did that work I am assuming you got an alignment done after words. I would ensure that the lower control arm mounting hardware at the frame is good and tight. I just recently had an issue where I would get a popping sound during certain situations and I just went and tightened them a little more and it has seemed to stop.
