Front End "clunk Noise" when transitioning into driveway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PilotJim3, Apr 17, 2016.
  1. Apr 21, 2016 at 8:53 PM
    PilotJim3
    PilotJim3 [OP] Member
    Jim
    San Diego, CA
    2013 Tacoma Access cab 4WD TRD 4.0 V6 5-speed auto, trailer tow pkg
    Custom 4 leaf spring pack to support 1,500 pounds 1,100 pound pop-up camper bolted on. LT "E" rated 10 ply tires.
    Today drove 432 miles = no "clunk". Tomorrow into the mountains towards Santa Rosa I go. Driving on uneven roads. Will see what happens.
    travis.diller likes this.
  2. Apr 21, 2016 at 9:01 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    My first gen did this as my driveway is pretty steep. It turned out to be my skid plate. If I didn't install it with weight on the tires it popped. Also my alignment cams were not torqued properly once and caused a clunk turning, snuggled them down and it stopped. Nothing so far on my 2015.
  3. Apr 21, 2016 at 9:09 PM
    Syncros
    Syncros Well-Known Member
    New sway bar bushings cured my clunk. Was an easy job until both welded nuts sheared off inside the frame on the drivers side.
  4. Apr 25, 2016 at 3:24 PM
    PilotJim3
    Jim
    San Diego, CA
    675 miles since fix = clunk gone
  5. Apr 25, 2016 at 7:44 PM
    t64mech
    t64mech Member
    Rick
    Riverside, Ca
    2014 Access Cab 4x4
    None yet, in the planning stages.
    Had a "clunking" noise coming from the driver's side, started when the half shaft went bad at 50K, dealer replaced the half shaft on Toyota's dime. Clunking was noise still there, took it to the dealer and they are now replacing the front diff and rear springs on Toyota's dime.
  6. Apr 27, 2016 at 8:51 AM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I too have the driveway clunk. No clue what it is.
  7. May 11, 2016 at 8:36 AM
    PilotJim3
    Jim
    San Diego, CA
    Fix update
    My mechanic found a technical bulletin mentioning the "diffential needle bearing" issue and found it to be out of spec when he replaced it.
    Two weeks ago I returned from a 1,300 mile road trip. Only heard "clunk" once on front drivers side. Lower ball joint may be some of clunk. If sound continues may replace them next as there is a tech bulletin on them also. No recall on either issue.
    Back home routine driving heard it once in front couldn't distinguish which side.
    G
  8. May 22, 2016 at 5:04 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I had the exact same thing on my truck....till today.
    Apparently the lower control arm cam bolts on these Tacomas seize up when they get old. Basically, these cam bolts go through the steel eye of the two bushings in the lower control arms. Eventually, water and crap gets in there and they rust. This causes them to seize to the bushing sleeve. When you hit a gutter, driveway, turn into a parking spot your LCAs move a good bit and the bushing sleeve holds tight till it breaks loose making the noise. You can feel it too.
    What I did was I pulled out the cam bolts one at a time and stripped the rust off with my dremel and a sanding attachment. Very quick work to get them cleaned up. If you can, it's a good idea to clean out the inside of the bushing sleeves too. Get as much of the rust and grit out as possible. Then lube up the bolt and the inside of the sleeve before reassembling. This will allow it to rotate around the bolt like Toyota originally intended. :D
    You'll need a jack to put the truck in the air, a 12mm socket to remove the skidplate, and a 19mm socket (and breaker bar) to remove the cam bolts. That's it.
    JustinL and vrod671 like this.
  9. May 22, 2016 at 5:15 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Subd
    I've got the same shit going on.
    ChadsPride likes this.
  10. May 22, 2016 at 6:59 PM
    Sidponcho
    Sidponcho Well-Known Member
    Dan
    Mine has been doing it since the day I brought it home new. Dealer checked it twice and said it was fine
  11. May 22, 2016 at 7:15 PM
    Sidponcho
    Dan
  12. Jun 29, 2016 at 1:09 AM
    \000/
    \000/ Well-Known Member
    Waimanalo, HI
    2016 DCSB 4x4 TRD Sport
    I've had a clunk for several months now and finally figured it out. Initially I thought it was the sway bar so I bought relocation bars and then I thought it was my LCA bushings. After reading another post I checked the body mount bolt behind my passenger tire and sure enough it was loose. Tightened it and the sound was gone! No harm in taking a look for the guys that still can't find where it's coming from.
    vrod671 likes this.
  13. Jun 29, 2016 at 1:17 AM
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Right on! I'm gonna a have to check this in the morning.
  14. Jun 29, 2016 at 1:18 AM
    \000/
    Waimanalo, HI
    Good luck!! Clunk drove me insane...lemme know how it goes
  15. Jun 29, 2016 at 1:38 AM
    #35
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Same here.
    :goingcrazy:
    Had it since last October.
    ChadsPride and \000/[QUOTED] like this.
  16. Jun 29, 2016 at 4:44 AM
    #36
    ItalynStylion
    Steven
    DFW, Tx.
    What would cause a cab bolt to get loose? I'm curious.
  17. Jun 29, 2016 at 4:59 AM
    #37
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I authored the thread that @TacoPhil linked. What was ultimately the issue your mechanic found on your truck? Leaf spring bushing?
  18. Jun 29, 2016 at 6:53 AM
    #38
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Mine were "extremely loose" from factory. Toyota blamed it on the guys who sprayed the Krown.
  19. Jun 29, 2016 at 6:59 AM
    #39
    TACO TX
    Kelly
    Denison ,Texas
    Checking cab bolts is part of the regular maintenance regimen per Toyota so I assume that they could have a tendency to loosen up periodically due to vibrations, road conditions, off roading. Ect.
  20. Jun 29, 2016 at 9:06 AM
    #40
    \000/
    Waimanalo, HI
    Mine happened right after I went off roading.
    ChadsPride and TACO TX[QUOTED] like this.
