front end clunk when braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by out_of_step, Oct 2, 2009.
  1. Oct 2, 2009 at 7:42 PM
    out_of_step
    out_of_step [OP] Member
    colorado
    07 Tacoma TRD V6 SR5
    I have a 2007 Tacoma V6 6spd with TRD it has 55,000 mi, and when I hit the brakes, there is a loud metal like clunk that comes from the front end. I did a search on this here and someone said that its the brakes pads moving in the caliper. I don't believe this is what my truck is doing, it kinda sounds like its coming from the front diff? any ideas?
  2. Oct 2, 2009 at 7:53 PM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    Sounds like your driveline needs to be greased. Look for your zerks on the U-joints on the driveline.there are 5 of them. Pump grease into them. This is using a standard grease gun. This seems to solve most of the reported clunking problems.
  3. Oct 2, 2009 at 8:05 PM
    out_of_step
    colorado
    Actually I've greased the whole driveline within 800 mi and the u-joints are good and plan on changing the diff, transfer, and tranny fluid once I pick up the fluid.
  4. Oct 2, 2009 at 8:11 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    +1. thats what fixed my clunk
  5. Oct 2, 2009 at 8:12 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Check the engine mounts.
  6. Oct 3, 2009 at 12:15 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    does it make the clunk when stopping in neutral? if not, it may really be the brakes???
    gl
  7. Mar 30, 2010 at 1:03 PM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    its the front brakes making the clunk, it will only do it the first time you step on the brakes in that direction. the pads are a floatig design and move when you step on the brake. its normal!
    BillsSR5 likes this.
  8. Apr 10, 2010 at 3:42 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    glad i found this thread ive been wondering the same thing for almost 2 years now. my "clunk" only happens the first time i brake in forward or reverse. kinda makes the brakes sound cheap or broken when i hear that clunk. oh well, as long as all is good i reckon
  9. Apr 13, 2010 at 4:41 PM
    taco157
    taco157 Active Member
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    I have that same problem... but if i repeatedly brake hard in the same direction it clunks Hard everytime.... and its not because the driveline needs to be greased.... its loud and very obvious... also clunks sometimes just driving down the road.... sometime you dont even have to hit a bump....
  10. Apr 14, 2010 at 3:31 AM
    taco157
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    Has anyone else had this problem.... what was the fix?
  11. Apr 18, 2010 at 6:42 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
  12. Apr 19, 2010 at 9:16 AM
    lizard1
    lizard1 Well-Known Member
    Tucson
    Desert Sand Mica/4x4 off road w/lock rear
    Leer cap, rear TSB, BFG All Terrains 10 ply 265/75/16, mud flap trim, black badges, AFE filter, 3" Toytec lift, 884 OME coils, add - leaf, Bilstein 5100 all around
    Mine does the same. Dealership said not to worry and an independent mechanic said the same. Has to do with the calipers. Usually clunks once and thats it.
  13. Apr 19, 2010 at 6:21 PM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    I added some generous amount of brake grease to the back of the brake pads on the driver side and my clunk is gone. My driver side Icon coilover also had some play in it so I tightened it up and that helped too.
  14. Sep 14, 2010 at 11:04 AM
    06stex
    06stex Well-Known Member
    Alex
    Corpus Christi, Texas 361
    06' TRD 6" Fabtech..limo tint
    6 inch Fabtech, Dirt Logic 2.5 coilovers, Light Racing UCAs 17x9 XD spy, 305 65 17 Extreme ATs, Limo all around, Kicker speakers,Kicker L5 10 inch sub, 400 watt kicker mono amp In dash Pioneer with Ipod cable, Flowmaster 50, bedmat, toolbox, K N Filter, cheapo seat covers, 6000k HIDs upfront, bhlm,DDM 5000K fogs, tailgate mod, and many more to come.
    TW any other solutions to this. My front end is clunking when i brake and sometimes at a turn. i greased my driveshaft and have tightened every single bolt up front. I just put new rotors, pads, UCAs ( Light racing) and my lower ball joints are strong. I do need new inner tie rods that im about to replace but i certainly dont feel that tie rods are making the clunk. Its quite loud but in so lost at this point. Any Ideas.
  15. Sep 14, 2010 at 11:27 AM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    Mine was doing this right after an allignment last week. Turns out the shop decided to only hand tighten the passenger side lower control arm. Glad it didn't come loose. Coulda been very bad.
  16. Sep 14, 2010 at 2:08 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Mine does this clunk too. Local dealer says it's the brake pads.. I do agree with them, but want it to stop..
    Loud clunks when applying the brakes the first time, or when hitting a pot hole.
  17. Jul 18, 2015 at 12:34 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    old thread but i too have been wondering this for some time. Only happens the first time I brake in forward or reverse. Glad nothings wrong.
  18. May 12, 2018 at 8:18 PM
    Tomboy77
    Tomboy77 New Member
    2013 Tacoma 4x4 Double Cab
    The clunk is so loud. Yes, only once after fwd or reverse. It’s the brake pads floating, so if you hit a pothole the may loosen out of place - when the brake is applied they’ll be forced back into place. It sure is annoying, and makes it sound like something is very wrong! We spun the tires while the front end was off the ground and watched & listened to it happen. Nothing we can do as far as I know. I think the pins that hold the pads in place wear down over time, just enough for the ‘clunk’ noise to alarm us!
  19. May 12, 2018 at 8:49 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Holy thread resurrection Batman!
  20. May 13, 2018 at 6:20 AM
    Tomboy77
    Tomboy77 New Member
    Lol! I know! :rofl:But it’s the one topic I found when I typed the issue into the search bar that applied to my Truck.
