Front end clunk while turning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BenSkiv, Sep 19, 2024.
  1. Sep 20, 2024 at 7:40 AM
    G007
    G007 Well-Known Member
    Gary
    Vancouver, Canada
    2023 Tacoma Premium Lunar Rock
    275 70 17 KO2 on 17" Bronze TRD Wheels AFE Intake Magnaflow Exhaust OEM TRD Pro Grill
    have you checked the cab mount bolts?
  2. Sep 20, 2024 at 7:46 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Or the cab mount bushings? Especially the radiator support bushings.
  3. Sep 20, 2024 at 8:23 AM
    BenSkiv
    BenSkiv [OP] Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    I plan to check them today. I think that might be the issue…
  4. Sep 20, 2024 at 8:27 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    What upper control arms are you running?
  5. Sep 20, 2024 at 8:31 AM
    Taco_Ventures
    Taco_Ventures Well-Known Member
    N
    SL, UT
    23 Taco OR DCLB
    I had to double nut my UCA bolt- it kept loosening up- only on the drivers side.
    Use a big pry bar at every bushing joint- its most likely a bad bushing and just pushing/pulling on the wheel doesnt have enough leverage to move it.
  6. Sep 20, 2024 at 8:38 AM
    BenSkiv
    Ben
    Maine
    Currently stock. Eventually I’ll either buy ones for the lift or just remove the lift. Need to figure that out before committing to either or.
  7. Sep 20, 2024 at 8:39 AM
    BenSkiv
    Ben
    Maine
    I tried a big pry bar on every joint and got nothing to pop or clunk…
  8. Sep 20, 2024 at 8:40 AM
    btgann02
    btgann02 Airborne Mekanic
    Billy
    2007 Blue Tacome TURD Off Road
    Teeny lift and wheels
    Haven't seen it mentioned, my 07 does the same thing but on my 07 it is very clearly bad cv axles that I will most likely just remove. Have you looked into your cv axles and boots to see the condition they are in?
    TheWildMan likes this.
  9. Sep 20, 2024 at 8:42 AM
    BenSkiv
    Ben
    Maine
    The side that’s clunking has a brand new CV as I just did the ECGS bushing maybe 2 months ago… it could be a bad one, but I’m not fully convinced yet.
  10. Sep 21, 2024 at 6:11 AM
    BenSkiv
    Ben
    Maine
    The two front body mounts are at least 34 ft/lbs which is the only real number I could find on here… caliper bolts are torqued, lower control arm bolts are torqued, shock bolts will be torqued briefly. If this doesn’t fix it, I have no clue what else to look at…
  11. Sep 21, 2024 at 7:10 AM
    BenSkiv
    Ben
    Maine
    Update, fixed it. Not entirely sure what did it. I replaced both outer tie rods and torqued every single bolt on the drivers side. No more clunk. Wish I knew exactly which one did it, thanks to everyone for the help!
  12. Sep 21, 2024 at 7:11 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Great to hear!
    BenSkiv[QUOTED][OP] likes this.
