Front end "Clunk"
Discussion in '1st Gen. Tacomas (1995-2004)' started by smokinglock, Apr 1, 2012.
  1. Apr 1, 2012 at 4:59 PM
    smokinglock
    smokinglock [OP] Member
    Ben a.k.a. "OC"
    Moyock, NC
    04 SR5 TRD Silver
    3" body lift, Spacers, AAL's, Rear Shackles.
    Hello all, need some help. I'm getting a front end clunk, almost like something is binding up then giving at all different times. It happens when wheels are turned and when they are straight, but mostly when i hit bumps. It's getting worse pretty quickly so am looking for some quick assistance/knowledge. Also, bought this truck used with a 3" body lift, spacers, AAL's and rear shackles. Any assistance is appreciated. :confused:
  2. Apr 1, 2012 at 5:02 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    I have the same exact clunk I think. I'll wait to see what info shows up here :spy:
  3. Apr 1, 2012 at 5:03 PM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    What kind of clunk? Can you identify if it is from the engine, driveline or suspension/etc..? What kind of engine/trans/4x4?
    All those lifting components can't be good put together with a body lift.
    If it is when you hit bumps seems like it might be a bushing is going bad somewhere. Certain side of the truck it comes on?
  4. Apr 1, 2012 at 5:06 PM
    smokinglock
    Ben a.k.a. "OC"
    Moyock, NC
    04 SR5 TRD Silver
    Seems like it comes more from the right front side, I know it's a Sh!*&y setup, but that's how i bought it, I've already updated my profile, but it's a 4x4 extra cab, 3.4 manual. The only other thing i've done is the grey wire mod.
  5. Apr 1, 2012 at 5:07 PM
    smokinglock
    Ben a.k.a. "OC"
    Moyock, NC
    04 SR5 TRD Silver
    definitely suspension/steering too, nothing else seems right.
  6. Apr 1, 2012 at 5:09 PM
    smokinglock
    Ben a.k.a. "OC"
    Moyock, NC
    04 SR5 TRD Silver
    Doesn't do it during braking more than any other time, what do you mean by contact points???
  7. Apr 1, 2012 at 5:17 PM
    Forster46
    Nick
    Mount Vernon, WA
    Right, didn't notice his is a first gen. Mine has been making the sound ever since I installed the lift. Nothing is loose or anything, and it clunks and makes a rattle sound whenever i hit small bumps, no idea what it is
  8. Apr 1, 2012 at 5:20 PM
    smokinglock
    Ben a.k.a. "OC"
    Moyock, NC
    04 SR5 TRD Silver
    Well the thing rides like a tank anyways. Don't know how long the shocks have been on it or the rest of the lift, but i can feel every ripple and pebble in the road as it is. Everything seems to be working but it's my DD so i want to fix it before it puts me at the bus stop..
  9. Apr 1, 2012 at 5:52 PM
    smokinglock
    Ben a.k.a. "OC"
    Moyock, NC
    04 SR5 TRD Silver
    Well this isn't settle but i gotta get off here for now. Anyone else has any ideas, please lend a hand. Preciate it...:thumbsup::thumbsup:
  10. Apr 1, 2012 at 5:56 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Probably your upper controll arm ball joint maxing out when you go over a bump. Does it clunk right after you crest over the bump when you suspension tops out?
  11. Apr 2, 2012 at 7:02 AM
    smokinglock
    Ben a.k.a. "OC"
    Moyock, NC
    04 SR5 TRD Silver
    No not really, it will do it when even when i'm just turning and moving lock to lock in a parking lot.
  12. Apr 2, 2012 at 8:57 AM
    natemoore2088
    natemoore2088 Well-Known Member
    Nate
    Idaho
    '97 Tacoma 2.7
    2" lift Pre-runner bumper Deck Plate Doug Thorley header Cherry Bomb
    Could be loose/worn out steering rack bushings if it happens when turning while parked, can you feel any play in the steering wheel?
  13. Apr 2, 2012 at 11:18 AM
    dorkmagus
    dorkmagus Well-Known Member
    Shane
    Bentonville, AR
    2012 Double Cab Tacoma TRD OR
    I chased a "clunk" in the front of my truck for months. It wouldn't happen all the time and would usually occur when I hit a dip in the road not a jolting bump. It finally happened in a drive through a few weeks ago and I could make it do it when I rolled forward and hit the brakes. I then could hear a faint sloshing liquid sound. That's when I realized it was the washer fluid sloshing back and forth. It would start doing it when the level got down to a certain point which is why it wouldn't do it consistently. :rolleyes: :eek:
  14. Apr 2, 2012 at 11:34 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    have you checked your lower ball joints?
  15. Apr 2, 2012 at 2:43 PM
    1998tacoma4x4
    1998tacoma4x4 Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    Maybe its the steering shaft clunk? The steering column is a two piece design, resulting in a less than stellar steering feel.
  16. Apr 2, 2012 at 3:39 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    That would be my guess too.
