front end clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hanrock, Jul 3, 2014.
  1. Jul 3, 2014 at 9:37 AM
    hanrock
    hanrock [OP] Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    hi i have a clunk in the front end when i apply the brakes in either foreward or reverse . if i roll ahead or back a few feet and apply the brakes hard its. there all seems tight except a small gap on both sides of the main bolt that goes through the upper control arm. is this normal hope you can see in the pic thanx you can see where the rubber bushing has made contact with the washer behind the bolt there is that much gap front and rear any help is appreciated
  2. Jul 3, 2014 at 12:16 PM
    skrazz
    skrazz 2013 SR5 4x4 4.0L AC
    Joshua
    St. Petersburg, FL
    2013 SR5 4x4 4.0L AC MGM
    Are you sure it's not from the loose brake pads? Does it always do this upon braking or just when going from fwd-reverse, or reverse-fwd?
  3. Jul 3, 2014 at 12:19 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Sounds like brake pads bud. Those washers on the uca's look like that..its normal. Mine did that also brand new and it could be axle wrap being an auto also. Nothing to worry about imo
  4. Jul 3, 2014 at 12:21 PM
    gearcruncher
    Canadain bumper technician
  5. Jul 3, 2014 at 7:35 PM
    hanrock
    craig
    sask
    Thanks for the help I'll pull the wheels off and have a good look in there
  6. Jul 3, 2014 at 7:44 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    That bushing "gap" is normal, its the same on all of these trucks.
  7. Jul 4, 2014 at 8:24 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I've got a clunk/click happening on my drivers side front wheel. Took it to the suspension shop that did an alignment on it a couple months ago. I thought a bolt may have come loose from that?
    Anyway, they checked everything out and said the suspension is tight. Couldn't find the reason for the "click".
    Happening when I hit larger speed bumps or there is some articulation in the suspension.
    Doesn't happen 100% of the time, more like 80%. Once it "clicks" it's usually quiet for a bit before it gets jarred enough to click again.
    Any ideas?
  8. Jul 4, 2014 at 9:12 PM
    hanrock
    craig
    sask
    I had an alignment done and after my front drivers spring and sway bar were touching each other mayb check that out
  9. Jul 8, 2014 at 7:47 AM
    skrazz
    Joshua
    St. Petersburg, FL
    Bad or missing spring bumpers maybe? [​IMG]
    I could see this making a sound upon braking since the front of the truck tucks with the front end weight plus hitting bumps might clack that arm
  10. Jul 8, 2014 at 1:06 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Wasn't there a thread that found the wheel well loose under the fender??
  11. Jul 8, 2014 at 2:34 PM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    check your sway bar bushings, i had a clunk too but only when i hit bumps, not when braking like yours... but they're easy to check and easy to replace.
