Front end "clunking" feeling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RelentlessFab, Feb 9, 2009.
  1. Feb 9, 2009 at 7:13 PM
    RelentlessFab
    RelentlessFab [OP] Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I noticed that when I took my truck 4wheeling the other day that when I drove over some 2-3" rocks and such that there was a clunking coming through the steering wheel. This wasn't there before so I was wondering what you guys think it is. I was almost thinking it has something to do with my spacer lift causing wear and play in something since i've heard negative things about them. Any ideas what it may be? Steering linkage? UCA? Steering shaft?
  2. Feb 9, 2009 at 7:26 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Steering shaft maybe. could be you tires rubbing against the inside of the well.
    Power steering???
  3. Feb 9, 2009 at 8:16 PM
    RelentlessFab
    Eric
    nothing to do with my tires. They're good. Its definitely something loose or worn.
  4. Feb 10, 2009 at 4:46 PM
    RelentlessFab
    Eric
    bumpity.......
  5. Feb 10, 2009 at 4:59 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I once lost the nut off the bolt that holds the upper arm in. It sounded like that. The bolts are installed at an angle, so it may stay in place, but be loose, causing the "clank". I replaced the nut and good as new.
  6. Feb 10, 2009 at 5:15 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    same symptoms on my truck. I have been over everything and cannot find squat. I may take it to the stealers some time soon if i dont find what it is. I think I've pinpointed the pop/clank sound to the front passenger side.
  7. Feb 10, 2009 at 5:27 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Front end clunks can be hard to trace sometimes, can you have someone drive while you sit in the passenger side, the noise resonating though the steering wheel may be fooling you.
    I once cracked a weld on a passenger side shock mount and had a hell of of time trying to track it down since the shocks seemed fine when I grabbed them and only clunked when under load that i could feel through the steering when going over bumps
  8. Feb 10, 2009 at 5:43 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    jack up the front of the truck..Grab wheel, and shake side to side and top to bottom. See if theres anything loose in the suspension
  9. Feb 10, 2009 at 5:53 PM
    RelentlessFab
    Eric
    all good info guys.
    I tried to do this a little when I swapped my regular tires back from my winter ones, everything seemed tight and fine. Only problem is, my UCA contacts my coil on full droop so I think that that would hold tension and hold it from moving any.
    I guess I'll wash the mud out of the wheel wells and check over all the bolts and stuff too just to make sure. I was kinda wondering if this may be a UCA ball joint issue from over extension from the lift but I don't really know. If that were the case i guess I'd have to get a new set of UCAs
