Front end creaking noise with video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fletcher37, May 18, 2025.
  1. May 18, 2025 at 7:07 PM
    Fletcher37
    Fletcher37 [OP] Well-Known Member
    PNW
    I’m trying to hunt down a front end creaking noise on my 2019 DCSB TRDOR. Front end has a lift with New-ish JBA UCAs, 2-3yr old Elka 2.5 with no resi, probably 3” lift, no swaybar.
    I hit every suspension joint and bushing I could find one by one with Wurth spray lube/grease. Still squeaks.
    I hit the cab mounts. Still squeaks.
    I hit the skid plate mounts. Squeaks.
    The UCAs were lubed ~1000 miles ago.
    the noise is present if I grab the front steel bumper and bounce the truck up and down and when I hit a bump or turn the steering wheel.
    Any ideas? I’ve lubed everything I find. Thanks!
    https://youtube.com/shorts/6DUITRVXN-I?si=UV46NXy2rfOAwHzt
