Front End creaks after offroading
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwikvette, Jul 6, 2019.
  1. Jul 6, 2019 at 9:13 PM
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    Here's why I'm asking - I work 12 hour days so the only real time I have to look at my truck are on my days off.
    With that being said, I want to order any recommended 'dry lubricants' and the sort and go by your guys suggestions.
    I took the truck across 20 miles of dirt roads, all while climbing and descending some steep grades; nothing a Prerunner with a locker can't handle.
    Anyway, after driving an hour and a half back, I parked it and ended my day. The entire drive back felt the exact same as it did on the way there; alignment was straight, handling was better than an 18 year old truck, you get it.
    Today, while backing up slowly out of my parking, I noticed a loud creaking. Almost sounded like a dry bushing rubbing against metal (I've heard the sound, so it's the best thing I can come up with). On my day off, I'm going to pressure wash the entire underside to remove all the dust and dirt. Afterward, I'm going to check my skid plate and bolts, as well as my sway bar and sway bar bushings.
    What other items should I check out up front, and after I have everything washed off with simple green and a pressure washer, what items should I keep lubricated up front?
    Keep in mind, the LCA bushings, LBJ's, and shocks are new as of 3 months ago.
    GQ7227 and cruiserguy like this.
  2. Jul 7, 2019 at 3:44 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    That does not mean a lot. Make sure you double check LBJ. All bolts are tight, ball is tight boot is not torn.
    cruiserguy likes this.
  3. Jul 7, 2019 at 5:26 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    My UCA bushings are shot and very creaky. Easy to pinpoint with the coilovers taken out; just move the UCA
  4. Jul 7, 2019 at 8:53 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I'll be checking those bolts as well.
    From a quick look underneath, no grease at all and the boots are intact.
    That's next on the list of items to replace.
    I'll check to see if it's the UCA's that are creaking.
    The creaking doesn't happen going over speed bumps or anything, only once in awhile when turning sharply at low speeds.
  5. Jul 12, 2019 at 8:05 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Removed both skid plates, noise still there
    Removed sway bar, noise still there
    Sprayed lube on the front body mounts, noise still there
    Tightened the one bolt that got loose that holds the radiator, noise still there
    Think if I replace the upper control arm bushings, that should do it? I was really thinking I should just throw on aftermarket UCA's.
  6. Jul 12, 2019 at 9:15 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    This is probably stupid but what about the crossmembers underneath the engine/trans? Just banging another thought here thinking about what lateral torque stuff may have happened.
  7. Jul 12, 2019 at 9:34 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    WHEN does it creek? When steering? when the suspension moves?
    Front or back?
    What equipment do you have? Stock or aftermarket UCAs?
    Leaf springs like to creek a lot...
    As far as what to keep lubed: anything with a zirk fitting. But that's not the kind of thing you should have to do after every 20 miles of dirt road. The only thing that may need semi-consistent lubing is if you have uniball style UCAs. Those are open to the environment, so they will tend to squeak if not lubed (dry type lube) fairly often.
  8. Jul 12, 2019 at 9:41 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    He's already answered all of those questions...
    "Front end creaks after offroading..."
    "... only once in awhile when turning sharply at low speeds"
    "I was really thinking I should just throw on aftermarket UCA's"
  9. Jul 12, 2019 at 9:44 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    My front end creaks bad on the driver's side, especially offroading but also if I hit dips of bumps in the road a little too hard. It's like this deep "UUUURK EEEK" barn door sound.
    It's definitely my front driver LCA bushing(s)...when I was under there doing my LBJs I could recreate it. I think you mentioned you had done yours though recently yeah?
    I recommend the WD40 Specialst PTFE Dry Lubricant....it's sold any most any hardware store, I get mine for cheap at Wally World. It works great for pretty much every other noise I have the on the truck, and the WD40 brand comes with the straw attached to the can so you don't lose it.
    If you know it isn't your LCA bushing I would look at the UCAs like you said.
  10. Jul 12, 2019 at 9:51 AM
    jbrandt
    Justin
    I've had plenty of noises that I SWORE were coming from the opposite end of the truck they were actually coming from. Hdell, I've had creeks that ended up being the air filter, not even suspension related, lol.
    This still doesn't really quite answer what I was meaning to ask. I meant while turning the steering wheel. 90% of the time you're negotiating a turn, your steering wheel is pretty stationary.
    I'll give you this one, I missed that.
    Minimag95[QUOTED] likes this.
  11. Jul 12, 2019 at 10:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I didn't check the cross member, though I did stare at it for a bit while underneath and think "I wonder if this needs to get torqued down"
    I'll check on my next days off this Wednesday/Thursday
    As @Minimag95 quoted, I did my best to answer this already.
    I have stock UCA's.
    Fox 2.5 front's, without reservoir.
    No spacer's or anything weird.
    Stock LCA's with new white line bushings in them as of 2 months ago.
    OME Dakar's in the rear, and yes I do have a squeak there. The rear noise has been there before I went off-roading and remains after I went off-roading; I've grown accustomed to it and it's easy to differentiate the noise coming from the front from that of the rear.
    If I step on my front bumper, or work my suspension up/down, I do not get the weird loud creak I'm experiencing.
    Thanks for quoting me in case other's missed what I said above.
    I did replace my LCA bushings just 2 months ago, as well as my LBJ's and it's really tightened up the front end. After having gone off-roading, I checked my LBJ bolts to ensure they did not loosen up or back out and I still have the noise.
    I did buy a dry film lubricant with Teflon, but have yet to use it anywhere other than the front body mounts.
    The noise is pretty loud, as it's louder than my rear leaf springs. The duration of the noise is kept short though, whereas the rear will continue to squeak as I go over dips.
    I noticed the noise happens more often when I'm turning and going down a small slope, causing the weight to slightly shift on the truck.
  12. Jul 12, 2019 at 10:55 AM
    eon_blue
    Azusa, CA
    I've tried dousing my noisy bushings with the PTFE dry lube but unfortunately it doesn't work very well on those...if it is a bushing issue with the UCA's it'll probably just come down to getting them replaced.
  13. Jul 12, 2019 at 11:01 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I know it’s more a common occurrence on 2nd gens, but it may be the core support.
    They are pretty thin metal to allow for crunching in an accident, and any sort of moderate fast or roughy offroad driving will make the core support creak and groan. This is due to the wimpy front support bushings and also just small tears or cracks in the support that develop.
    Over bumps, dips, turns, cracks in the pavement, even a leave will make my trucks core support noisy.
    BillsSR5 likes this.
  14. Jul 12, 2019 at 11:01 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Which spray lube do you get the best results from for quieting down the poly bushings? I know l you've tried a few different ones
  15. Jul 12, 2019 at 11:14 AM
    jbrandt
    Justin
    I just grease them occasionally... You're not likely to be able to get lube into the bushing area where the motion actually occurs without disassembling them anyway.
    But if you feel the need, that PTFE stuff @eon_blue mentioned is probably your best bet.
  16. Jul 12, 2019 at 11:21 AM
    eon_blue
    Azusa, CA
    It works on my squeaky poly bushings for the leaf springs, at least a bit...but for my OEM LCA bushings it doesn't quiet those down, but I think they are past the point of quieting and just need replaced
    The WD40 Specialist Dry Lube works best for most noises on the truck, since it's dirt/dust resistant...all the others like white lithium, silicone spray, etc attract dirt like crazy
    cruiserguy[QUOTED] likes this.
  17. Jul 12, 2019 at 11:23 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    pressure wash your leafs.
  18. Jul 12, 2019 at 11:35 AM
    jbrandt
    Justin
    The problem with using any sort of lube on OEM rubber bushings, is that there isn't really anything that should be rubbing against itself. The rubber flexes and twists, the outer steel sleeve is press-fit into the control arm, and the inner steel sleeve is mounted firmly to the frame (or should be, lol)
    Poly bushings are known to squeak because there is motion between the inner sleeve and the bushing.
  19. Jul 12, 2019 at 11:43 AM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    Get a can of Tri-flow and spray it into your upper control arm bushings?
  20. Jul 12, 2019 at 11:45 AM
    eon_blue
    Azusa, CA
    yeah I think my LCA bushings are just plain ol' shot, no amount of lube or grease is going to make them quiet.
    My poly bushings on the leaf springs drive me nuts. I have the greaseable bolts and no amount of grease makes them quiet, and the ones on the passenger side front hangar "pop" and "clunk" unless I spray them with the PTFE spray a couple times a week. No idea how the PTFE spray gets in there and quiets those down but it does, for a few days anyway.
    One of these days I'm just going to take the poly bushings out and go back to normal OEM rubber leaf spring bushings and normal bolts. I never had half the noises with those that I do with these poly ones.
