Front end driver side clunking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bakerboys, Aug 25, 2022.
  1. Aug 25, 2022 at 8:10 AM
    Bakerboys
    Bakerboys [OP] Member
    Parker
    Blue 00 Tacoma
    Looking for diagnostic tips to find a clunking in my front end, I hear it after hitting bumps sometimes or when I slow down/accelerate but not every-time.
  2. Aug 25, 2022 at 8:25 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    There are many things that could be making a clunk on a 22-year-old truck. It could be as simple as a sway bar end link bushing, or as bad as a wheel bearing, and everything in between (upper and lower ball joints, upper and lower control arm bushings, worn shocks and or worn mounting hardware, CV axles if you have 4wd). You really just need to get the tire off the ground and use a pry par to find out what moves. If you haven't replaced anything, then you'll be looking at doing all the things I just mentioned.
    wilcam47 likes this.
  3. Aug 25, 2022 at 8:27 AM
    psychic_legume
    psychic_legume Well-Known Member
    2002 White Tacoma TRD
    I had very similar symptoms and it turned out just one of the nuts had fallen off the sway bar end links. Could literally be anything
  4. Aug 25, 2022 at 8:28 AM
    Bakerboys
    Parker
    Blue 00 Tacoma
    Sway link is new and cv is solid, What’s the best way to check the upper and lower ball joints
  5. Aug 25, 2022 at 8:30 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Noises can be real tricky !!
    Check out the whole truck might be a loose exhaust system.
    Maybe the rear suspension.
  6. Aug 25, 2022 at 8:30 AM
    psychic_legume
    Take the wheel off and use a pry bar, not a ton of force but check if they move up and down in the direction of the bolt. Any play at all should be treated with a lot of suspicion. IIRC the Toyota spec for those ball joints is "Any perceptible movement" means it's bad.
  7. Aug 25, 2022 at 8:30 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Honestly though, if you haven't replaced the lower ball joints, you should replace them no matter what else you find. If you search around here you'll find many folks who have blissfully unware they were driving around on failure prone parts.
    Bivouac and wilcam47 like this.
