Front End Floats
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2manycars, Aug 10, 2020.
  1. Aug 10, 2020 at 3:45 PM
    2manycars
    2manycars [OP] Member
    Dave
    2013 Silver Tacoma TRD Sport
    Hey Taco World! I am the second owner of a '13 Double cab TRD. It had a bad front end whine when I bought it, turned out to be a wheel bearing. Tires were needing replaced so I put on Yokahama Geolanders, Bilstein shocks, raising the front to level with the back. Looks good!
    Now the issue. From day 1 with the steering wheel in the neutral position, it would wander right or left at really any speed. If I am driving into a crosswind, no issues of course. Yes, the truck has been aligned and a very trustworthy and knowledgeable shop has looked for other worn, or bent parts that may be the cause. Nothing. Anyone else have this issue or have an idea what it may be?
  2. Aug 10, 2020 at 4:00 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    The specs are good from the alignment but what were they? Is the truck lifted?
  3. Aug 10, 2020 at 4:05 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, what are your alignment numbers and what are you running for tire pressure?
    ovrlndkull likes this.
  4. Aug 10, 2020 at 4:07 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    JBA UCAs will get you right back to stock feel.
  5. Aug 10, 2020 at 4:12 PM
    2manycars
    Dave
    I did not get the print out of the alignment. I am not a techie person when it comes to that, sure I could get them though. The float was the same with a set of Kelly tires before. That was with the factory Bilsteins and Kelly tires. I was sure with the new Bilstein's, the adjustable fronts set on the mid lift and with the new Yokahama's it would be better. It isn't. I am running 32 lbs all the way around for pressure.
  6. Aug 10, 2020 at 4:20 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lack of caster if you are using OE upper control arms still. That's your issue. It's a very common thing for them to need replacing once you get lifted.
  7. Aug 10, 2020 at 4:25 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I’d call and get your alignment numbers and post them. How much lift do you have? When I upgraded my suspension the caster was at the bottom edge of the spec and wandered. Possibly get another alignment where you specify the caster on the high end or UCAs to easily address it ... but this is all theoretical until you know the numbers.
  8. Aug 10, 2020 at 4:39 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    If you had the loose or floaty feeling before and after this work it sounds like you are fairly new to the truck what was the previous vehicle? Is their play in the steering wheel before your input moves the wheels.
  9. Aug 10, 2020 at 4:55 PM
    winkel
    Corydon, IN
    Can we assume you got the alignment after you installed the Bilsteins?
  10. Aug 11, 2020 at 3:28 AM
    2manycars
    Dave
    There is little to no play in the wheel before input. Yes, alignment was done after the tires and Bilstein's. I have 8 vehicles in the family and have driven a variety of all types of vehicles. If you are recommending upper control arms, are these aftermarket or OEM and why would this be affected?
  11. Aug 11, 2020 at 4:12 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    As the suspension droops or lifted the caster angle decreases. The more pos caster the more stable and less "loose" feeling at speed the more neg. caster the better at low speeds and maneuvering. So with the truck lifted it decreased your caster aftermarket control arms allow you to gain this caster back without affecting any other measurement as the caster is built into the arm in most cases. My only other suggestion besides this being a new vehicle and not use to the feel would be a tire issue but you had it with 2 different sets. I have replaced my front end components multiple times and never had any issues. Could be an issue in the rack like with the hydraulics or something I don't know. Hard to diag. or know without actually seeing and feeling for myself.
  12. Aug 11, 2020 at 4:48 AM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I have bilsteins 5100s, 265/75/16s, coils and an AAL that resulted in 2.5" lift. When I got my truck aligned from a shop I've used for years (trustworthy to me), the truck wandered. I got my numbers and had 0.5 caster. The recommendd range is somewhere around 1-3 (IIRC the 2005 range is 1.2-2.7). Once I added UCAs (dirt king group buy on this site) the caster jumped to 2.9 and it made a world of difference. There are plenty of threads on here where this is discussed in detail, and many with lifts similar to mine found a shop that could get the alignment into spec. For me, the UCA made sense and it helped tremendously. As a sanity check I'd call the shop and see if they have the numbers, post them and you can either rule that out or focus on it.
    One more note -- changing the caster moves the wheel forward / back relative to the wheel well. Before my UCAs with the low caster, my tires would rub the front fender as I would reverse as i approached full lock down a hill (steep driveway). After the UCAs the rubbing is gone.
  13. Aug 11, 2020 at 6:07 AM
    2manycars
    Dave
    I knew I could count on this group to help and help you have, thank you. I never paid too much attention to front end things, out of my league and wanted to trust those that were trained in that area. I will check the numbers from the shop and post or let you know what I have done to fix the issue.
    Unrelated, but coming up as I turned 150K the other day, how soon should I be thinking water pump?
  14. Aug 17, 2020 at 6:50 AM
    2manycars
    Dave
    Help! The shop is ordering caster kits, as they believed them to be damaged. They changed the caster to nearly 1 and the tires now rub in the wheel well. With OE control arms yet am I wasting my time or can it be aligned to track neutral? If so with the factory parts where is a good # on caster to try?
  15. Aug 17, 2020 at 7:36 AM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I think more information would help ...
    • what size tires?
    • how much lift?
    • what are the current alignment numbers?
    • when do the tires rub? all the time or only when you're turning right or left? is it at or near full turn or just barely?
    • do they rub in the front of the wheel well? back?
    this is probably my ignorance, but I've yet to read about tacoma's needing a caster kit? I would guess maybe the LCA cam bolts are seized and they're replacing them? Or maybe a set set that allows for more adjustmnet? I know the current LCAs can be adjusted ... and my understanding is that with a lift, you're limiting the caster you can get with the stock cams, but this sounds suspicious. What do they expect the caster kit to accomplish?
    As for # to try, I'd suggest 2.5 -- top end of the range, but it sounds like in this case they want to get you in range and call it done.
    As for OE control arms, my guess is you're spinning your wheels and aftermarket UCAs will help. Most come with roughly 2' delta from OE so you slap on some JBAs or DKs and you're at 3 and then the alignment techs can focus on camber and toe, which is clearly where they're more comfortable.
  16. Aug 17, 2020 at 12:53 PM
    2manycars
    Dave
    Tires: 275/75, 1 size larger than stock
    Lift: 2 1/2"
    Alignment: All he said was caster was now at .89, wheel is visibly further back in the wheel well. Did not provide all #'s as they have to get the caster kit in and installed
    Rubs at half turn to the left at the back of the wheel well
  17. Aug 17, 2020 at 1:10 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Caster kit?
  18. Aug 17, 2020 at 1:11 PM
    2manycars
    Dave
    They want to put in caster kits, yes
  19. Aug 17, 2020 at 1:12 PM
    gotoman1969
    What are they saying is in this kit?
  20. Aug 17, 2020 at 1:17 PM
    gotoman1969
    Just looked it up. Keeps us posted. I’m curious if the eccentric actually lets them find 2+ degrees of caster.
