front end grind HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by ryang012, Jul 20, 2014.
  1. Jul 20, 2014 at 5:32 PM
    ryang012
    ryang012 [OP] New Member
    02 dbl cab
    Alright guys...
    02 Tacoma double cab 3.4 non trd 4.10.gears man locking hubs.
    Grinds bad.
    Does not grind in 2wd... Unless I lock the hubs then it does grind in 2wd Hi, it grinds in any 4wd as long as hubs are locked. Was a little low on diff fluid so I drained and replaced. I put 85-140 in. No change and no there wasn't any metal pieces in drain pan.
    Thanks in advanced
  2. Jul 20, 2014 at 6:47 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Sounds like you need to take your hubs off and clean them. I had a bolt and washer come loose in mine. Had to buy a new bolt from it rolling around in there. Solved my problem, hopefully yours will be this simple. Welcome to TW!
  3. Jul 21, 2014 at 3:59 PM
    ryang012
    02 dbl cab
    Thanks I'll look in the coming days
