Front end grinding noise.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Metallikatz3, Jan 11, 2010.
  1. Jan 11, 2010 at 3:25 PM
    Metallikatz3
    Metallikatz3 [OP] Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    So ever since its been really cold out before my truck gets warmed up I hear a pulsating grinding noise from what sounds like the front right corner. Its like 1 second on, 1 second off. It lasts for about 2 miles going around 50mph then it goes away once I get on the highway. Once my truck is warmed up though it goes away.
    I'm thinking maybe a wheel bearing? Any thoughts?
    I cant feel any vibrations associated with the noise though which is throwing me a bit.
  2. Jan 11, 2010 at 3:28 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    almost sounds like that.or maybe a bad brake pad.
  3. Jan 11, 2010 at 3:41 PM
    tacopromatt
    tacopromatt Matt's Pro Taco
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    Do a search for "growling". You can read about others, myself included, who had had or are having similar issues.
  4. Jan 11, 2010 at 3:42 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    True, my brakes could be hung up. I'll check out everything later this week when I'm installing my 885's
  5. Jan 11, 2010 at 3:53 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    well,i dont no about hung up but if u have a broken pad it could take a bit to settle in hence the noise is gone.just a thought.
