Front end grinding vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thunter_3, Apr 1, 2008.
  1. Apr 1, 2008 at 3:41 PM
    thunter_3
    thunter_3 [OP] Florida Redneck
    Franklin, VA.
    2007 TRD Sport, 4x4 Quad Cab Short Bed
    Westin Nerf Bars & Bull Bar, Armor Lid Tonneau Cover, PopLock, TRD Seat Covers, AFE Stage 2 CAI.
    Hope someone could help me pin point this issue. The past couple of day I have noticed while turning left or right from a stop I can feel an intermittent vibration that feels like metal to metal grinding. It feels like its on the driver side only. Once I straightened up it goes away. Now today going down the road at about 50mph I can feel a light vibration throught the floor and it still feels like it coming from the same location. Tried the search feature on here but didnt really find anything close to what I am feeling. I was thinking that its either a wheel bearing or cv joint. The truck only has 7500 miles on it.
    any suggestions would be great.
    going to make an appt to have it looked as soon as possible.
  2. Apr 1, 2008 at 3:44 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Does it feel like your front wheels have been locked when you're turning?
  3. Apr 1, 2008 at 3:46 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i dont know hope the stealer helps
  4. Apr 1, 2008 at 3:48 PM
    thunter_3
    Franklin, VA.
    no
    I will take off from the stop and will be rolling and then will feel the grinding as im turning I will feel it two or three times during the turn and then it stops.
  5. Apr 1, 2008 at 3:53 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Terry,forgive the stupid question but...is the truck in 4wd?...just a thought.
    Welcome btw.
  6. Apr 1, 2008 at 3:53 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Make an appointment first. Then go out and check your tires for wear, screws, rubbing locations. If it's something stupid, I'd rather not give up my truck for the day, but if it isn't stupid, you could be deteriorating further. Toyota could deny a warranty claim if it is too far worn.
  7. Apr 1, 2008 at 3:57 PM
    thunter_3
    Franklin, VA.
    no
    its not in 4x4. thats a ligitamate question. Looking down in that area I dont see anything that is missing, broken, bent. etc.
  8. Apr 1, 2008 at 4:00 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    have you tried putting in 4 wheel drive and going for a drive in the mud? What about locking it?
    Part of 4 wheel drive maintenance is that you use it occasionally.
  9. Apr 1, 2008 at 4:03 PM
    thunter_3
    Franklin, VA.
    if I dont get off road and do any four wheeling then I do at least put it in four wheel time to time to keep everything exercised down there.
  10. Apr 1, 2008 at 4:11 PM
    squad314
    Marc
    Glad you see I wasn't trying to be a wiseass.....My thought was that it inadvertantly got switched into 4 and was reacting on dry pavement...Good luck with a fix,Toyota will make it right.
  11. Jul 11, 2008 at 5:38 PM
    clemsonxplorer
    clemsonxplorer Member
    Rockwall, TX (DFW)
    2007 FJ Cruiser 4x4
    Lots, about to sell it and come back to Tacoma though.
    Thunter 3,
    What did the vibration end up being? I am experiencing the same thing.
  12. Jul 11, 2008 at 5:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like it could be the LS chattering. Ive had the same problem.
  13. Jul 11, 2008 at 6:23 PM
    clemsonxplorer
    Rockwall, TX (DFW)
    2007 FJ Cruiser 4x4
    yea i feel like mine is coming from the rear. Is it a quick fix for the dealer?
  14. Jun 21, 2011 at 2:03 PM
    Brad Fuchs
    Brad Fuchs New Member
    BRAD
    RED DER
    Stock 07' TRD
    I am experiencing the same problem, it seems for now that it is worse when you accel through a corner, left hand turns are worse than right but it is present for both. It gives an intermittent 1,2,3 type vibe that is worse under accelleration than just coasting through a turn, it is not bad now but is also getting worse so I would like to get it fixed. I have just only begun to notice it at higher speeds although it is subtle.
    thx in advance
    Brad
  15. Jun 21, 2011 at 2:07 PM
    edc
    edc Well-Known Member
    ILLINOIS
    09 tacoma trd crew cab 4x4
    rcd 4.5" lift,relentless fab front bumpers,trd cai,17x9 motometal955,flowmaster40 muffler,cobra sxt cb,k2motor headlights,kl71 kumho tires
    MINE DOES IT TOO FROM 25MPH AND UP, PLUS I HEAR KNOCKING SOUND WHEN GOING THRU BUMPS AND MAKING A RIGHT AND LEFT TURN. THE GRINDING SOUND DOES NOT GO AWAY EVEN AT 4HI. IT STARTED AFTER LIFTING WITH 4" RCD LIFT.
  16. Sep 3, 2011 at 10:50 AM
    PipsTaco
    PipsTaco Well-Known Member
    Jarrod
    Central Valley, Ca
    2020 TRD Off Road
    I would love to know if anyone has pinpointed this problem and fixed it. Mine also makes a griding noise, you can feel it more than hear it. Mine does it mostly on inclines turning left or sometimes right. More so when turning left. I have checked the diff fluids, checked the heat shields to make sure they are not rubbing, checked brake pads. Seems to be coming from the front left.
  17. Sep 3, 2011 at 11:28 AM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    Sounds like it could be a wheel bearing. Have a tire place check it out and test drive it. I had no play in the wheel but a vibe on driver front. I just installed a new one and drives like a dream. Some people have a prob with the front diff
  18. Sep 23, 2011 at 9:05 AM
    PipsTaco
    Jarrod
    Central Valley, Ca
    2020 TRD Off Road
    I had the exact same issue. From a stop, grinding sensation when turning left, sometimes turning right. More promiment on incline turns. Swore it was coming from front end. I could feel it in the steering. Took it to a good auto shop and they also thought it was coming from font end, possibly bearings or tranfer case not disengaging all the way. Took it to a better auto shop for 2nd opinion. I described it to him just like i did above.
    Without hesitation he crawled underneath the rear end, filled my rear diff which was 1/2 qt low, added LS additive and bingo, problem solved. It was LS chatter. Just goes to show how vibrations in the rear can be felt in the front end! It may not be true for everyone, but if you are experiencing the same grinding/vibrations please check your rear diff levels and additive. I felt stupid afterwords when i found out it was something so simple, but im glad its fixed.
    kylerfarr5 likes this.
