Front End Growling Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoastieZ87, Jun 11, 2013.
  1. Jun 11, 2013 at 11:55 AM
    CoastieZ87
    CoastieZ87 [OP] Member
    Elizabeth City, NC
    06 4x4 SR5
    285 BF A/T's, ARB front bumper with Warn 8000 winch, PIAA offroad 520s and custom built bed rack with recovery gear mounts.
    Hey everybody. I'm new to this forum and was hoping to find a little advice about a problem I started having with my 06 Tacoma. Within the last month or two ive been noticing a louder than normal road noise/growling coming from the front end. Its hard to tell exactly what side its coming from, but im thinking its more from the left. Ive gone through a bunch of threads, some dating back to 09, with little success. People have been experiencing similar front end growling, but none of their symptoms seem to fit perfectly. Growling increases with speed and is unnoticeable at slower speeds (leads me to believe its a bearing issue). It does not go away when i engage 4x4 (unlike symptoms in past threads), but it goes away and runs smooth when i make sharper right-hand turns (maybe the left wheel bearing is taking a load). I put it up on a lift and pulled the wheels off to examine the left side. Noticed a little up and down slop in the brake rotor/hub assembly and the normal slop on the shaft where it comes out of the front diff. CV joints are solid, front diff oil is clean, topped off and not leaking. When i spun he left front brake rotor (w/o wheel on) and did notice that it spun a little rough, but wasnt sure if that was normal. Finally, im not noticing any drag on either side in the wheel, but can feel the vibe in the wheel and pedals. Any help would be appreciated! Thanks!
    Z
  2. Jun 11, 2013 at 12:23 PM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    wheel bearing is my guess.
  3. Jun 11, 2013 at 12:34 PM
    JayEMS
    JayEMS Active Member
    Bright's Grove, ON, Canada
    08 DCLB 4X4 TRD Sport Black
    BHLM, Avid Light Bar, Extang Solid Fold tonneau, Interior LED's, GROM iPhone interface, Michelin A/T2, Weathertech liners, 2011 FJ 17" wheels powder coated black
    My 08 just had the exact same problem. It was the wheel bearing. It does't take much in the bearing for it to get loud. When I removed mine there was hardly any sound or grinding at all it just got snagged a bit every turn by hand. A good bearing should turn completely smooth with no sound at all. Really easy to replace on your own but it does need to be pressed out and back together (the shop around the corner from me did it in a pinch)
  4. Jun 11, 2013 at 12:36 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    sound like a wheel bearing
    easy fix....
  5. Jun 11, 2013 at 3:31 PM
    CoastieZ87
    Elizabeth City, NC
    06 4x4 SR5
    Thanks for the help fellas. That's pretty much what I figured but i wanted to get an outside opinion before I started loosening bolts. Any suggestions for finding replacements next to driving down to Toyota and paying $$$ for their parts?
  6. Jun 12, 2013 at 8:35 AM
    JayEMS
    Got mine at Car Quest (Canada) $150 with 3 yr warranty. Was $285 at Toyota.
  7. Jun 12, 2013 at 8:39 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    got mine from ebay and the seals from rock auto......
    then you can have a trail spare as well all for under $100
  8. Jun 12, 2013 at 8:41 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Needle bearing if it goes away in 4x4
  9. Jun 13, 2013 at 2:20 PM
    CoastieZ87
    Elizabeth City, NC
    06 4x4 SR5
    Cool. Ill check them out. The noise definitely is still there when it's in 4x4. That's what made me think it wasn't something more with the diff but after I change the wheel bearings and the noise is still there ill take a look at the needles
  10. Jan 27, 2014 at 9:40 AM
    psy212
    psy212 New Member
    PETE
    NC
    06 TACOMA
    I literally just fixed this exact problem yesterday for my front left hub one my 06 Taco. Look up a username on here, nj636, or send him a private message. He sells the whole hub replacement for $180 bucks with shipping and it is bolt on, so no need to find a press to do bearings and all that. I went with the whole hub instead of just the bearings (if you read a lot of other threads they'll say do both at the same time or you'll just have the same problem shortly). I did the whole job, from jacking it up to setting it back down on it's wheels in about 40 minutes. Got rid of the growling noise immediately.
  11. Feb 3, 2014 at 4:50 PM
    ksmoove757
    ksmoove757 Well-Known Member
    Kenneth
    VA BEACH
    2012 Tacoma Sport 4x4
    I just started getting the growling noise/vibe on the drivers side. I have a 2012 sport 4x4 with billies all around with 33's, the front set to the highest. It's been almost 6 months since I had it installed, and driven around 5k miles. I just started hearing the growling noise after I went through a flat field of snow last week. Do you guys think its my wheel hub?
