Front end high pitch whine
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomazach, Sep 6, 2011.
  1. Sep 6, 2011 at 11:20 AM
    tacomazach
    tacomazach [OP] Well-Known Member
    Zach
    Mississippi
    01 doublecab 4x4
    Hey guys I did a quick search but its tough to search from the phone so I apologize if the answer is right under my nose.
    I noticed a high pitch whine today coming from the front end. It's while rolling. While hitting the gas or brake or anything it still whines. It's tough to hear in the open but is ear splitting while going through a parking garage. Very high pitch. What is going on?
  2. Sep 6, 2011 at 11:26 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    bump for an answer
  3. Sep 6, 2011 at 1:21 PM
    tacomazach
    Zach
    Mississippi
    01 doublecab 4x4
    been driving around the parking garage in circles cause it's the only place I can hear it well trying to figure it out. The only thing to add is that I THINK it's coming from the passenger side.
  4. Sep 6, 2011 at 1:35 PM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    Dunno if its relevant but... When my replacement alternator failed and started overcharging the system. I had a noticeable high pitch whine coming from the engine bay. almost like a SC whine.
    If the whine is constant, it has to be something that is rotating...
  5. Sep 6, 2011 at 1:40 PM
    tacomazach
    Zach
    Mississippi
    01 doublecab 4x4
    It's constant only when the truck is moving. When at a stop or parked it does not make the noise.
  6. Sep 6, 2011 at 1:55 PM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    More than the wife knows!
    could be the wear indicators on the front brake pads to where they are just starting to touch?
  7. Sep 6, 2011 at 1:56 PM
    tacomazach
    Zach
    Mississippi
    01 doublecab 4x4
    would the wear indicators whine even when not braking?
  8. Sep 6, 2011 at 2:07 PM
    meatman
    Greg
    Murphy N.C.
    not sure on the taco's but on my old buick they did
  9. Sep 6, 2011 at 2:15 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    My truck does the same thing but only between 15 and 40 mph. It sounds like it is the front passenger side also. I have no clue what it is.
  10. Sep 6, 2011 at 5:16 PM
    tacomazach
    Zach
    Mississippi
    01 doublecab 4x4
    I'm not sure if it has a top end on mine. I'm not sure if it stops or if it's just wind noise drowning the sound while I'm going down the highway.
  11. Sep 6, 2011 at 10:49 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine did. It's tough to explain without looking at it but there's that little lip of rotor on each face that isn't contacted by the pad so it doesn't stay polished and will rust. I know the 6 lugs have a completely different caliper set up but on mine the indicator was hitting that little rust lip when rolling and when I touched the brakes the pad would move inwards enough to not hit the lip and actually stop squeaking. It was driving me nuts so I finally pulled the front wheels to investigate and this was my discovery.
  12. Sep 7, 2011 at 6:10 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Does it change pitch with road speed or engine speed? Does it change volume/pitch when cornering left or right?
    Road speed changes= driveline issue.
    Engine speed changes= engine issue.
    Inspect your brakes pads for thickness and your wheel bearings for excessive play JIC.
  13. Sep 7, 2011 at 6:17 AM
    tacomazach
    Zach
    Mississippi
    01 doublecab 4x4
    No changes that I can tell. I'll get on the brakes as soon as I get a free minute.
  14. Sep 7, 2011 at 6:35 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    There has to be some kind of change. Nothing rotates at the same speed constantly. Focus, Daniel-san!
  15. Sep 7, 2011 at 6:44 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    :D:bananadance:is it your turbo?
    Francoi88 likes this.
  16. Sep 7, 2011 at 6:57 AM
    tacomazach
    Zach
    Mississippi
    01 doublecab 4x4
    Well I can only hear it well when I'm going through the parking garage :rolleyes: It's tough to hear going down the road but it's there. I'll focus :cool:
  17. Sep 7, 2011 at 7:06 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Keep in mind the pads are always a hair's width from the rotor. You might even hear them touching the rotors at low speeds. So if your pads are down far enough, the wear indicators will always be in contact with the rotor and will "squeal" when your Taco is in motion.
  18. Sep 7, 2011 at 7:33 AM
    mark73
    mark73 Noob :-/
    Poconos
    Green '02 TRD SR5 4x4
    Auto-Starter, 5-point harness rear seats, XM
    Check the heat shield on the inside of the rotor. Could be bent and touching the rotor as it spins. Can be annoying as hell.
  19. Sep 7, 2011 at 7:40 AM
    brs127s
    O'Fallon, MO
    Very true, but it makes a loud, scraping noise and not a high pitched squeal. Trust me, I just learned the hard way when I installed my LR UCAs and Toytec coilovers. :rolleyes:
