Front end issue/noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jp_flynavy, Oct 12, 2020.
  1. Oct 12, 2020 at 11:11 AM
    jp_flynavy
    jp_flynavy [OP] IG: @TrailLimoOverland
    2015 Tacoma DCLB
    I am stunned with this squeak issue I’m having. Though that maybe my wheel bearing is going bad.
    Brakes are good, excuse the grease on my uniball, it’s on it’s way out and I packed some grease in thinking it might be it.
    The noise goes away with brakes applied, and does not present itself in reverse.
    Sound picks up in volume and frequency as I speed up and sounds like a metal to metal tapping.
    https://youtu.be/Gi2V6oHXKNM
  2. Oct 12, 2020 at 2:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It seems the noise is happening once per revolution of the tire.
    In the video, if you watch the valve stem, it looks to be around 1 o’clock area.
    Have you jack the front end up and spun the tire?
    How are the CV Axles and joints looking?
  3. Oct 12, 2020 at 2:30 PM
    jp_flynavy
    2015 Tacoma DCLB
    I just noticed that too. I cannot replicate the sound with the front end off the ground. It only happens when driving.
    CV is in good condition, no play. I am stunned.
  4. Oct 12, 2020 at 4:08 PM
    TnShooter
    Deogee
    STOCK
    When the front end is off the ground, the cv is at a different angle then when on the ground.
    Some guys have jacked the truck up under the control arm to get it to “normal” driving conditions.
    I have never done this, yet. So I’m not sure where the best spot is to place the jack.
    I’d have to crawl under there and take a look.
  5. Oct 12, 2020 at 4:11 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    If you have a floor jack, jack the truck under the lower control arm just enough to get the wheel off the ground and spin the tire.
    Also have someone apply light brake (enough to still be able to spin the tire) and see if the noise is there/goes away.
    jp_flynavy[OP] and TnShooter like this.
  6. Oct 12, 2020 at 4:48 PM
    jp_flynavy
    2015 Tacoma DCLB
    I will have to give that a try. That's how I discovered that my upper TC uniball was shot.
    Will do.
    TnShooter[QUOTED] likes this.
