Front end issues due to concrete barracade
Discussion in 'New Members' started by WarenL, Oct 7, 2020.
  1. Oct 7, 2020 at 10:01 AM
    WarenL
    WarenL [OP] New Member
    Waren
    2001 Tacoma Xtra cab 4x4
    Lock them up into avoid hitting the lady in front of me I crank the steering wheel into concrete barricade on driver side. Front end is all over the place and steering wheel is cocked right. Wheels screeching on turns. Anybody have any ideas of what my problem could be? Thank you
  2. Oct 7, 2020 at 10:02 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    You bent something in the front
  3. Oct 7, 2020 at 10:38 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW...:popcorn:
    FishnTx, Black DOG Lila and Micatom33 like this.
  4. Oct 7, 2020 at 10:43 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    Welcome to TW :cheers:
    Might need to get under there an see what is bent
    Tie rods?
  5. Oct 7, 2020 at 11:00 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TW Waren
    buckhuntin-tacoma and FishnTx like this.
  6. Oct 7, 2020 at 11:08 AM
    FishnTx
    South East Texas
    ‘17 OR
  7. Oct 7, 2020 at 11:15 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    visual inspection frist and foremost
    repair/replace parts that are visually cockeyed
    then a date with the alignment rack
    that should prob set your straight, however keep in mind it is always possible that certain things are bent that can not be identified with the naked eye
    oh and :worthless:
    buckhuntin-tacoma likes this.
  8. Oct 7, 2020 at 11:20 AM
    eon_blue
    Azusa, CA
    At the very least you need an alignment for sure, even hitting a pothole can knock an alignment out.
    But hitting a barricade at speed, I would bet money you bent something (or more than one somethings)...spindle, lower control, tie rods maybe, etc.
    Take it to a shop that does alignments and they should be able to tell you what you need.
  9. Oct 7, 2020 at 11:23 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Check for leaking fluids.
  10. Oct 8, 2020 at 12:02 PM
    WarenL
    Waren
    Ok thanks y'all. I don't see anything bent underneath. But it looks like I have a bent camber? The wheel is leaning in, at the top, probably about a inch. And my steering wheel is cocked about a qtr turn to drive straight.
  11. Oct 8, 2020 at 12:08 PM
    WarenL
    Waren
    Oh and the alignment shop says it is unalignable right now. They showed me the chart that shows where my wheels are supposed to be and where they are currently. The driver side wheel supposed to be at zero and it's at 1.3 but also my passenger wheel is at 1.1. I bought this truck totaled at an auction on that passenger side so I'm thinking the passenger wheel was already messed up and I did the driver side in. I guess my question is what part is it that would affect how the wheel looks in terms of leaning top to bottom. Like a camber. Thank you guys!!
  12. Oct 8, 2020 at 12:15 PM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    Sounds like you bent the lower control arm
  13. Oct 8, 2020 at 12:22 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Had a similiar accident a few years ago. probably bent the inner tie rod, when it bends it shortens which pulls the wheel toed in. You may also have damaged the steering rack, look for fluid where you inner tied rod meets the rack & loosen the boot and see if there is fluid inside it. If so highly likely that the rack is damaged too.
  14. Oct 8, 2020 at 12:24 PM
    tcjacado
    tcjacado Well-Known Member
    Or the spindle. May have bent the uca/coil bucket for the shock too.
    Bummer.
  15. Oct 8, 2020 at 12:27 PM
    rnish
    Tacoma 2nd gen
    Sounds expensive. Did you contact the insurance company?
  16. Oct 11, 2020 at 9:05 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome!
