Front end lift on 2019 tacoma 4x4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1blktrd, Feb 25, 2019.
  1. Feb 25, 2019 at 3:06 PM
    1blktrd
    1blktrd [OP] New Member
    Alex
    2019 black TRD
    Want to have the front end a little higher than the back. (California lift) but I been reading that later you will run into problems if you do this kind of lift. Wanted to hear if this is true or not. And if it's to change the upper a-arms to have it . Then it will happen. Thanks in advance ✌
  2. Feb 25, 2019 at 3:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    Where you been reading this?
    Clueless what you are asking here........... but if it's about changing control arms to be able to still properly align the truck, that's typically something that seems to happen around the 3" plus mark.
  3. Feb 25, 2019 at 4:34 PM
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    UCA's fix alignment and shock clearance issues. You should be fine with a little lift up front. Just throw some sand bags in your bed for a few weeks to see if you like it. Your mpg's will take a hit due to aerodynamics though.
  4. Feb 25, 2019 at 4:49 PM
    IRISHFAN
    IRISHFAN Well-Known Member
    Jeff
    SE Pennsylvania, Elverson
    2019 Tacoma TRD Sport DCSB 4X4 M/T Cement Gray.
    Stock
    Do you ever put any weight in the bed ? It’s going to look really odd if you do with the front lifted higher than the rear.
  5. Feb 25, 2019 at 4:52 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    A little reading may clear up questions:
    What you need to know about lifting a 2016 Tacoma - Presented by Toytec Lifts
    Best 3 inch lift kit 3rd gen tacoma
    3rd gen Lift kit help
  6. Feb 25, 2019 at 4:53 PM
    momoe65
    momoe65 Well-Known Member
    2017 Super white TRD OffRoad
    Full LED upgrade toytec lift SCS wheels w/ cooper STMaXX clazzio seat covers
    be sure to aim the headlights down after...
