Front end locked up while in 4 wheel in snow. why???
Discussion in 'Toyota Trucks & SUVs' started by Detjensyota, Jan 31, 2011.
  1. Jan 31, 2011 at 1:42 PM
    Detjensyota
    Detjensyota [OP] New Member
    mike
    2000 4x4 v-6 supercharged tacoma
    Trd headers, Trd Supercharger, sway-away racerunner coilovers. Full front fiberglass hood and fenders, full 2011 Magnaflow off road exhaust. kevlar Mtr 33/12.50/15 tires . full front race bumper and rear bumper. etc
    I was in my 4x4 tacoma in about 7inches of snow driving about 15 miles per hr while in 4 wheel drive when all the sudden my front end locked up and i started to slide. I slammed in the clutch and about had a heart attack. I can still drive in 2 wheel drive but if i try to put it in 4x it wont budge . oh Man what did i doooooo.
  2. Feb 1, 2011 at 9:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Crawl under the truck and start poking around. Is the front drive shaft intact? Are the u-joints OK? Put it in neutral....grab the front driveshaft and spin it with your hands. Does it spin freely? Put it in 4WD and spin the driveshaft by hand - what does it do?
    Shift it back-n-forth from 2WD & 4WD - what does it do? Is the 4WD light still on in 4WD? do you hear anything when shifting? Is it hard to shift?
  3. Feb 1, 2011 at 9:30 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    :eek::eek::eek: I hope its nothing too serious.
  4. Feb 1, 2011 at 4:26 PM
    Detjensyota
    mike
    thanks janster ill try and get back to you on whats going on. i appreciate all insight on this . It will shift in and out of 4wheel drive and the 4wheel drive light does come on but once it is in 4wheel drive it will not move forward or backward.The front drive shaft is intact and the u-joints are ok.
  5. Feb 1, 2011 at 4:27 PM
    Detjensyota
    mike
    If it is the front ring and pinion is it easier or harder than doin the rear. I have replaced the rear myself and it was not so simple.
  6. Feb 1, 2011 at 8:05 PM
    Janster
    Jandy
    Lancaster, PA
    The truck won't move at all in 4WD?? Are your wheels straight? Have you tried rocking it back-n-forth?
    Have you tried engaging 4LO - just to see if it'll move?
    Something else to try - remove the front driveshaft and drive in 4WD.
  7. Mar 9, 2023 at 9:33 PM
    Ironworker84
    Ironworker84 Well-Known Member
    Eric
    2001 White Tacoma 4X4
    Was there a solution to this problem. My 01 is doing the exact same thing
