front end noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMo510, Aug 25, 2010.
  1. Aug 25, 2010 at 4:10 PM
    TacoMo510
    TacoMo510 [OP] newb
    Bay Area
    98 2.4 5spd
    k&n drop-in air filter, deckplate mod
    i just did a brake job and everything seemed fine before that. now there is a consistent "clunk" sound coming from my driver's side front end. sometimes it almost sounds as if i have a flat tire. and when rolling at around 0-10mph the clunk is heard much more clearly and it sounds more like a screeching/grinding noise. also when making hard turns i can feel it under the floorboard.
    it hasn't affected my driving much. it sounds much worse than how it actually handles, i mean, i can barely feel it through the steering wheel at all.
    my uncle said he had gone through a similar situation and that i should check out and replace the cv boot. is there anything else i should also take a look at?
    this has been driving me crazy and i can't quite figure it out. PLEASE HELP!
  2. Aug 25, 2010 at 4:12 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Not sure. Sounds kinda like a cv. Did it do that before the brake job?
    If there semi or metalic pads, they might grind for a bit but not make the sound you are describing.
  3. Aug 25, 2010 at 4:18 PM
    TacoMo510
    TacoMo510 [OP] newb
    Bay Area
    98 2.4 5spd
    it didn't do it before at all. it seems as if it has gradually gotten worse after the brake job.
    yeah, i know it's not the brakes.
